I had the same problem, but I read on another post that if the steering wheel is put down into the lowest position that wires get pinched & the right turn signal will not work, so I put the wheel up one notch and viola! I'm making safe right turns again!
I knew something was up because everytime my boyfriend drove my truck, the signal would work, but not when I drove it!
I love this site, I've learned ALOT!
I've got the same problem in that my blinkers don't work when the steering wheel is in the lowest position. So isn't there a way to fix it other than not using the bottom position? If wires are getting pinched, or whatever, there must be a way to resolve it permanently.
Does anyone know the solution to perminately fix this problem with no signal unless steering column is adjusted at least half way up? (Pinched wire problem).
