f3 disc brake help needed
Old Nov 26, 2009 | 11:06 AM
bigredmays's Avatar
bigredmays
I just bought a 1951 f3,iam wanting to put disc brake on the front.Any ideas? Does any one know of any newer chassis that are a close match?
Thanks Bill
bigredmays@yahoo.com
Old Nov 26, 2009 | 06:37 PM
jim collins's Avatar
jim collins
Thanks Bill
Bill I see you are new here so wellcome, If you are thinking of a frame swap ypu may need to google in 51 ford frame swap. I don't think the search feature will work for you until you get more post in .It won't work for me most of the time and I have been here for a while. I'm sure somebody will come along giving you advise how to do it or not do it. I'm doing a frame change of my own, so if it comes out okay it will be here , if not I will advise why not to do it . Some use s-10 ,some different fords, some keep their frames and update all of the components on it . JIM
Old Nov 26, 2009 | 07:33 PM
vintage tin's Avatar
vintage tin
if you are looking for a kit to do this,check out speedway,s site .they have a kit for $250.00 or so.
i have not done this but others here seem to like it.
Old Nov 27, 2009 | 02:01 AM
bobj49f2's Avatar
bobj49f2
No one that I know of makes a conversion kit for the F-2/F-3 trucks, only the half ton F-1.
A former member, Oilyowl, did a disc brake conversion on his '52 F-3. He longer owns the truck and has deleted the images in his gallery but he gave me permission to use his information for a tech page on my web site.
F-2/F-3 Front Disc Brake Conversion
A brake conversion would be a lot simpler than a chassis swap, IMO
Old Nov 27, 2009 | 11:50 AM
KJLYPW's Avatar
KJLYPW
I used the front calipers and brackets off a 75 F-250, a 77 4x4 front disc and new studs, some machine work and hole filling, re-drilling on my 48 F-68. Same doner truck used all the back brake system (with some axle flange modification) and got 5 16.5 wheels and an new tires!! Updated brake system and no widow makers all in one go!
Had to relocate the shocks to the back side of the front axle, modify the inner fenders some. Pictures of the disc conv in my gallery.
Old Nov 27, 2009 | 12:35 PM
bobj49f2's Avatar
bobj49f2
Just to set the record straight, I mistakely used images from Kevin's gallery in my tech page. I had images both from Kevin's gallery and Oilyowl's images in the same file and I used the images I saved at the same time I saved information Oilyowl sent me. I'll fix the page as soon as I get home and have a chance get on the home computer.
Sorry Kevin, I sent you a PM.
Old Nov 27, 2009 | 08:46 PM
bobj49f2's Avatar
bobj49f2
I updated the page tonight.
Old Nov 27, 2009 | 09:25 PM
KJLYPW's Avatar
KJLYPW
Nice work Bob- all about sharing information- keep on truckin.
Old Nov 28, 2009 | 06:38 AM
vintage tin
sorry about that bigredmays,i didnt mean to mislead you .i forgot i switched my m-68 front hubs for a 53 f-1,so i could have the 5 bolt.
the speedway kit will work for this but not the 8 bolt.
Old Jun 23, 2010 | 10:51 PM
wolfpak's Avatar
wolfpak
another newbie 51 f3
hi guys, sorry if this is not how to get info but i need a 51 f3 brake drum....please direct me.
Old Jun 24, 2010 | 07:41 AM
MCarlson's Avatar
MCarlson
I just put the speedway kit on my F3. As mentioned, it changed my pattern to 5 bolt. That's fine with me though as it will match the 9" I have for the back. It's gonna have hubcaps over the bolts anyway.
Mike
colokerrie
Oct 9, 2012 04:49 PM
brushman23
Large Truck
Mar 11, 2012 01:09 PM
marks500
WTB - Parts & other
Jan 18, 2011 05:05 PM
23109(c)
Sep 6, 2010 10:08 AM
fredco
1947 and Older Ford Trucks
Aug 27, 2004 12:16 PM
