injectors getting louder???
Old Dec 1, 2009 | 07:31 AM
  #31
MapleShadeDiesel's Avatar
MapleShadeDiesel
My sticks made a louder noise at idle when my fuel was low also. Did the in tank fix with the hutch and harpoon mods. After that if my sticks get loud it's because I am about out of fuel. My truck would do this when it was stock and no tunes, and only when i sit for a min or so, when you hit the peddle it would go away.
Old Dec 1, 2009 | 07:49 AM
  #32
DP-Tuner's Avatar
DP-Tuner
PREMIUM SPONSOR
Originally Posted by big poppa
I too notice its alot quieter with the B5 I run versus the 100% petro diesel. I don't put anything else in unless i'm traveling, then I get whatever is avail. Wished I knew you guys were up this way, would have stopped by to say hello..
We attend Fall Brawl put on by the Mason-Dixon TDC every October in Dillsburg.
__________________
Jody & Diane Tipton- DP-Tuner®
FTE Legacy Sponsors since 2006
Custom tuning for 7.3l, 6.0l, 6.4l,6.7l, Ecoboost,
Get Tuned! 828-221-0076 ext. 802
Become our Facebook Fan
Old Dec 2, 2009 | 02:53 PM
  #33
billyturbo's Avatar
billyturbo
Wow! I can see I opened a can of worms. Thank you everyone for your input. I'm not a pro mechanic, although I wish I was and am working at getting there. But by reading everything here. I guess it could be something other than the injectors I'm hearing. I guess I'm wrong. Maybe by changing out my straight pipe caused the actual combustion to change since there is more backpressure with the HUGE magnaflow muffler. I'm not complaining about the noise , thats what diesel is all about excluding 6.4's and CR's . And by the way , it has not done that noise again sitting at a light. It must have been because it was cold in north GA ,and I'm used to FL weather. So , in other words. My injectors are probably fine, but if they aren't its a good excuse to grab some for Riffraff
So what am I hearing when I change to 80e? cause its a major noise change. Thanks everyone.
Old Dec 2, 2009 | 03:03 PM
  #34
CampSpringsJohn's Avatar
CampSpringsJohn
My guess is the advance in timing.
Old Dec 2, 2009 | 03:06 PM
  #35
big poppa's Avatar
big poppa
Got yaa
Old Dec 2, 2009 | 03:18 PM
  #36
aklim's Avatar
aklim
If that is what you want to do, that is a poor excuse. What you need to say is that you are trying to save fuel and so you go to the Single Shot injectors. Say Stage II AC Codes?
I think you are hearing a combustion noise change. Injectors buzz and if they are muffled by the VC and the sound deadening material, I doubt you can hear the change. OTOH, the engine noise is not as muffled and much louder so you probably can hear that.
Do you have PMRs or Forged Rods? http://67.19.132.3/dieselinnovations...g2_itemId=1524
Old Dec 2, 2009 | 07:56 PM
  #37
billyturbo's Avatar
billyturbo
I have not inspected it myself, but from what I understand. only early 99's have forged rods . so I don't think mine is at 2001. right?
Old Dec 2, 2009 | 09:41 PM
  #38
aklim's Avatar
aklim
No, UP TO early 01s have forged rods. Late 01s have PMRs. Mine was late.
Dirtscooter250
Aug 19, 2016 06:23 AM
jmb2011
27
Apr 28, 2016 07:29 PM
IJRoorda
Jan 24, 2014 09:30 AM
Finz250
6.4L Power Stroke Diesel
Mar 23, 2012 07:15 AM
Visseroth
31
Jul 27, 2011 12:54 AM
