Bronco II Ford Bronco II
88 B2 4x4 Shifter problems
Old Nov 24, 2009 | 08:18 PM
JB B2 owner's Avatar
JB B2 owner
Got my money out of this one. This was an extra car that I just couldn't get rid of - too much blood sweat and tears. Around 250K Kids broke it. First it was a problem shifting into reverse and then the high gears. NOW Locked in gear, can't shift it out. Suspect a broken shift fork. Ready to drop the trans and replace the shift forks. Dropped the bottom pan and no pieces. Have never rebuilt a trans but lots of engines and other stuff & my father -in -law has done GM cars.
Appreciate any insights.
Also: I can't tell - can the FM146 transmission be unbolted from the clutch housing without removing the housing from the engine first?
Jerry
Old Nov 25, 2009 | 08:14 PM
TrussGod's Avatar
TrussGod
[quote=
Jerry[/quote]
I dont know about the rebuilding, but I can tell you that you will have to remove the trans from the motor. The bolts are inside the housing that hold it to the transmission.
Walter
Old Nov 25, 2009 | 11:22 PM
rebocardo's Avatar
rebocardo
You should be able to push it out of gear with the engine off, that might indicate a blown slave cyl.
I posted a link a few months ago to the site for getting parts for the FM-146.
Old Nov 29, 2009 | 05:58 PM
JB B2 owner
I was just hoping that the trans could be taken off the housing. Read another thread which suggested dropping the exhaust.
When I got it back, the shifter wouldn't move at all. Completely frozen in place. We tried rocking the Bronco backwards and forwards and nothing happened. We had to slide the Bronco on and then off the trailer to get it home.
I dropped the pan to see what I could see. No pieces or parts. Now I have the control housing off. I can now move the shift rails through all of the positions. So maybe it's the Slave Cylinder?
ColeT24
Sep 21, 2014 06:27 PM
buckthedog
Jul 25, 2014 12:55 PM
fordtrck302
Apr 5, 2008 05:52 PM
Jharger
Jan 21, 2006 10:57 AM
drpconstruction
Dec 17, 2005 07:19 AM
