Bronco II Ford Bronco II
spring swap
Old Nov 17, 2009 | 07:50 PM
steve,541's Avatar
steve,541
spring swap
have heard that springs out of an explorer will go under my 89 broncoll is this true an is it worth the time cuz i like to play in the oregon mud an will be putting cut well fender flares on next week an the springs at the same time if the spring thing is true thanks steve
Old Nov 18, 2009 | 03:32 AM
rebocardo's Avatar
rebocardo
Yes, four door explorer. It is worth it.
Old Nov 18, 2009 | 08:15 AM
steve,541's Avatar
steve,541
thanks will do it on vacation. will most early years of explorer springs work an will it lift it much
Old Nov 28, 2009 | 10:54 PM
mudslinging79's Avatar
mudslinging79
bout an inch and a half height increase, but really cuts down on the body sway when turning. well worth the hour to swap
Old Dec 1, 2009 | 11:12 AM
RomerB2's Avatar
RomerB2
I'd recommend swapping in some new polyurethane bushings as well when springing for it. It doesn't cost much, saves your more $$ in the long run, and gives you a better ride.
