Charging problem
Old Nov 24, 2009 | 06:44 PM
drumfield's Avatar
drumfield
Charging problem
'85 F250, 4x4, 460cid. I've replaced the alternator and the regulator, yet when i start the truck, the ammeter "bounces" like a ping-pong ball from side to side, all the way to the internal stops. Any ideas?
Old Nov 24, 2009 | 08:40 PM
ctubutis's Avatar
ctubutis
Have you measured the voltage at the battery, both with engine off and it running?
Old Nov 24, 2009 | 08:55 PM
vortilon's Avatar
vortilon
I would guess either you have a wire misplaced or the regulator is bad. The overvoltage relay is going bananas.
I assume the regulator has a bar plug that is fool proof so look at the alternator wires. If you are sure you have those wires correct then try another regulator.
I once went through three before I had one that worked.
Old Nov 25, 2009 | 05:29 PM
drumfield's Avatar
drumfield
Will try tomorrow. Nothing better to do (that's the way i like it). Thanks
Old Dec 27, 2009 | 08:31 PM
drumfield's Avatar
drumfield
Update: tried 5 different vr's, didn't fix the problem. checked the harness going from the alternator to the vr, and it looked like s**t, so I decided to look for a different one. The only one I could find locally was from a '86 with internal vr. Bought a "75 amp" reman from Auto Zone, and with the "new" harness, the problem is solved. Thanks for the help and advice.
Uncle Meat
Jan 19, 2015 09:57 AM
hunter1988
Appearance & Dress-Up
17
Feb 16, 2006 06:01 PM
Goodold71
Oct 2, 2004 12:43 PM
kable
Electrical Systems/Wiring
Aug 23, 2004 09:44 PM
badboyina67
Apr 9, 2002 12:40 PM
