CCV mod
Old Nov 23, 2009 | 03:34 PM
officer131's Avatar
officer131
Question CCV mod
I purchased the mod and installed it. I couldn't find it in the directions, but witch way does the switch go.
At a three o'clock position or the down six o'clock position?
I have the CCV mod i from BD.
Thanks,
Al.
Old Nov 23, 2009 | 04:01 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Switch for the CCV mod????? Never heard of this. Do you have a pic of it?
Old Nov 23, 2009 | 07:29 PM
Ponyboychris's Avatar
Ponyboychris
Look here - page 10:
http://www.dieselperformance.com/pro...stroke_CCV.pdf
I think he's asking about the drain valve. 3 o'clock is closed, 6 o'clock is open.
Old Nov 23, 2009 | 08:33 PM
maevans's Avatar
maevans
I think Chris found your answer, nice job.
The one I copied for you Chris is working fine. Thanks again.
Old Nov 23, 2009 | 09:52 PM
officer131's Avatar
officer131
Yes, it is the drain valve that I was thinking of.
To confirm I should have the valve closed or open?
Old Nov 23, 2009 | 10:13 PM
mueckster's Avatar
mueckster
Closed.......
Old Nov 23, 2009 | 10:46 PM
ChunderDownUnder's Avatar
ChunderDownUnder
Looks like the drain valve. Open it periodically to drain the oil build up. The top cannister near the vavle cover filters the oil out of the crankcase vent and routes the clean air back into the air intake. The drained oil runs down to that catch can which should be drained every oil change.
Old Nov 24, 2009 | 07:18 AM
Ponyboychris
Glad it worked out. After one year of having mine on the truck, I cannot be happier. I just inspected the scrubbers and they still look good. I drained about a tablespoon of oil out of the trap.
Big Sky
Jul 9, 2014 01:56 PM
F100Mann
20
Sep 10, 2013 06:41 PM
suds
Nov 8, 2012 05:47 PM
roosplash
Sep 11, 2011 09:46 PM
snapper1
Apr 18, 2003 01:23 PM
