Timing mark
Old Apr 2, 2003 | 12:53 PM
snapper1's Avatar
snapper1
Timing mark
new to I-6 engines.
Looking down at the front of the engine there is the timing indicator attached to the top left (11 o'clock) above the harmonic balancer. On the top is a timing indicator built into the timing cover.My question is that when using a timing light my mark is on the right side of the balancer about the 3 o'clock position. Am I 180 out? Runs ok
Thanks
Old Apr 2, 2003 | 04:26 PM
mantta's Avatar
mantta
Timing mark
If you look at the underside of the truck, you will find another one on the lower right side. That one is the correct one to use.
Old Apr 18, 2003 | 01:01 PM
snapper1's Avatar
snapper1
Timing mark
I have looked and can not locate the timing indicator you mentioned. How did Ford attach it. Pan bolts? Timing cover?
It may have been removed at some earlier time or riped off when offroad. Any Sugestions?
Thanks, Snapper1
Old Apr 18, 2003 | 01:23 PM
mantta's Avatar
mantta
Timing mark
On my 88, 4.9 it is on the passenger (right) side, just above the line where the oil pan meets the block. It appears to be a bolted on marker. My only suggestion would be to find a marker at a junkyard or there is a possibility that Ford still carries that part.
Azuber01
Jan 19, 2017 08:22 PM
Obowersox26
Sep 17, 2016 09:21 PM
deputydog03
Modular V8 (4.6L, 5.4L)
32
Apr 9, 2016 12:06 AM
Pgercak
Feb 18, 2015 05:59 PM
stractor
Apr 17, 2002 01:38 AM
