Transmission Choice Help!!
Old Nov 22, 2009 | 11:28 PM
MLTM2010's Avatar
MLTM2010
My band and I just recently purchased a 1990 ford E150. It has a 300ci I6 and a 3 speed automatic transmission. We are pulling a 6x8 trailer full of band equipment and five passengers in the van. We are having trouble getting up to speed with this combination. The van won't go more than 55mph and usually hovers more like 45-50mph with the throttle wide open. Second gear seems to get us to about 50 but there doesn't seem to be enough rpm's when it shifts to third. Would a different transmission help? Is the motor just to small (I've towed with a 300 before and had no problems)? Please help us with suggestions. We tour full time and need to be able to go hwy speeds.
Thanks
Old Nov 23, 2009 | 01:31 AM
95_Dually's Avatar
95_Dually
I think you need a van with a bigger engine. JMHO
Old Nov 23, 2009 | 10:11 AM
Old93junk's Avatar
Old93junk
I think you need to pull the codes from the OBD1 and tell us what you get, sounds like something is wrong. You should get lots more power than that, almost sounds like the catalytic converter might be collapsed/clogged, most likely not a trans related problem.
Old Nov 24, 2009 | 02:47 AM
rebocardo's Avatar
rebocardo
Did you buy it from someone, such as a rental or lease company, that might have put a governor on it or had it rechipped?
Old Nov 24, 2009 | 11:32 AM
bashby's Avatar
bashby
sounds like you could use a lower rear end gear ratio
Old Nov 27, 2009 | 05:39 PM
andyman7931's Avatar
andyman7931
you described exactly what I found with my truck when I first towed my 28' trailer. I had 3.08 gears behind my 3 speed transmission, with 3.73 gears it could pull the load all day long at 65.
Old Nov 27, 2009 | 10:50 PM
Ford_Six's Avatar
Ford_Six
Yup, high gears in it. Most E150s with the 300-6 got 2.75 or 3.08 gears. Mine's got 2.75s, and it's anemic in a headwind. If you're going to be touring and towing with this van, go for a 3.55 rear end. I used to have an F250 with a 300-6 and 4.10 gears, and while it would turn a little faster than I liked on the freeway, it wasn't bad towing. I hauled a 70 Galaxie over a pass, and came back with another F250 on the trailer, it hauled them both just fine.
Old Nov 28, 2009 | 07:38 AM
rikard's Avatar
rikard
As previous posters have said check for a restricted exhaust, computer codes, and vacuum leaks.
There is a sticker on the door post that will ID the rear axle ratio and transmission installed in the van. There should also be a tag on the axle. I think you can decode it on this site. I've had 3.55s and 3.08s and the 3.55s were much better in all aspects not just towing. Rear axle gear changes should be done by a shop or just change out the entire unit from a JY. $200-$300
regards
rikard
Old Nov 29, 2009 | 03:52 PM
stormyrider's Avatar
stormyrider
I have pulled a two way horse trailer with a F150 with the same engine transmission combo with 2400 pounds of horses plus hay and tack that added another 600 pounds and never batted an eye at 70 mph. I'd say you have a problem somewheres. If it still has a catalytic convertor on the exhaust you may have a plugged convertor. These will cause what you discribe.
Old Dec 2, 2009 | 06:24 PM
Ford_Six's Avatar
Ford_Six
The trucks, except for the economy F100s, got lower gears. The vans got high gears for economy. They weren't really intended to tow anything, but you could order them with gearing down to 3.73s. High gears make getting to speed and maintaining speed much harder.
sea2seajt
2004 - 2008 F150
Oct 8, 2014 01:32 PM
bb1982
Nov 4, 2012 07:36 AM
Solomon_Man
Sep 14, 2010 12:23 PM
johnnygrado
All Things Towing
Jun 22, 2010 08:17 AM
SteveOntario
Feb 17, 2007 12:41 PM
