Dimmer Switch Removal
Old Nov 22, 2009 | 04:31 PM
ReadOrDie_WoW's Avatar
ReadOrDie_WoW
Ok so I have a problem with my instument lights not coming on, I was taking the dash bezel off (hit a snag cause I can't figure out how to take the **** out of this models dimmer switch) and the lights for the gauges came on for a second and went off again, so theres prolly a loose connetion somewhere or whatever. But now I'm stuck cause I can't get the dang **** off, I know on the older models theres a button you hit to get the **** off, is it the same and if so wheres the blasted button? :P
any help is apprieciated
~RoD
Old Nov 22, 2009 | 04:37 PM
Diesel_Brad's Avatar
Diesel_Brad
yes. here is a button to push to remove the whole rod. BUT if you turn the ****, look where the rod goes into the back of it. You will see a little recess/ Take a small screw driver or pick and put it in that recess and pull towards you, there is a small metal clip that will release the ****. Hope my explanation is good enough
Old Nov 22, 2009 | 04:44 PM
ReadOrDie_WoW
ahh awesome! thank you very much, will let you know if I got it out
~RoD
Old Nov 22, 2009 | 05:11 PM
ReadOrDie_WoW
~RoD
yup came right out, I'd prolly still be screwing with it if ya hadn't told me, thanks again mate
~RoD
joannev
1997 - 2003 F150
Nov 22, 2022 07:16 PM
csonni
40
Jun 21, 2020 06:42 PM
brbuchanan
May 24, 2016 12:08 PM
slickrock01
Sep 28, 2009 09:40 PM
Patrick2002
Oct 14, 2002 05:47 PM
