How do I? (remove head-light switch knob)
Old Oct 14, 2002 | 03:54 PM
Patrick2002's Avatar
Patrick2002
How do I? (remove head-light switch ****)
I have a 74 F-250. I am trying to remove the instrument panel bezel and came across a problem:
I can't seem to get the headlamp switch **** off. It is mounted THRU the instrument bezel and the washer switch next to it pulls right off, no problem. But, you must remove the **** on the light switch to get the bezel off.
I don't want to reef on it and break it. Is there some secret?
Old Oct 14, 2002 | 04:33 PM
Graffe's Avatar
Graffe
On the part of the headlight switch that is behind the actual plastic bezel and metal dash, there is a plastic 'pin', if you will, that you will need to depress. It is about the size of an aspirin pill. Just push it down and pull out the **** (with the stem coming with it). You can get to the pin by way of reaching up under the dash and on top of the headlight switch, but it is hard. I get to mine a lot easier by just taking out every screw and tweaking the plastic bezel until I can reach in behind it and press down on the pin. I'll see if I can find a picture of the thing you need to press and I'll update this post for you.
Graffe.
Old Oct 14, 2002 | 04:37 PM
Graffe's Avatar
Graffe
Looks like Dennis has a picture of it in his archive. He posted a picture of it in this thread:
[link:www.ford-trucks.com/dcforum/61_79/11839.html|Switch Removal Thread]
Graffe
Old Oct 14, 2002 | 04:47 PM
Patrick2002
Thanks guys! That picture helped!
Patrick 2002
:P
Old Oct 14, 2002 | 05:47 PM
Torque1st's Avatar
Torque1st
Posting Legend
csonni
40
Jun 21, 2020 06:42 PM
Blaster900
Mar 8, 2017 09:11 AM
78 PEB
Dec 25, 2015 02:27 PM
Fydaman
Jan 27, 2012 03:15 PM
ReadOrDie_WoW
Nov 22, 2009 05:11 PM
