Wheres my fuel filter?
Old Nov 22, 2009 | 10:27 AM
84 f250 6.9's Avatar
84 f250 6.9
just would like someone to post a pic of where its at , also what additive would you all reccomend I use to clean it out . On my idi diesel I fill the fuel filter full of seafoam and it works AMAZING but idk how psd might be dif what you guys think atf? diesel clean? or sea foam?
Old Nov 22, 2009 | 02:26 PM
DRRXR's Avatar
DRRXR
FF
http://www.intellidog.com/dieselmann/injtop.jpg
Ford diesel 6.9 7.3 IDI
http://www.who-sells-it.com/images/c.../pdf_20585.pdf
Hope that helps
I like the seafoam
Rocky
Old Nov 22, 2009 | 02:27 PM
TheTowingCowboy's Avatar
TheTowingCowboy
Ona 7.3 its right in the valley, if yours has the factory cover on it, it flips up and right there it it, its a big circular bowl in the middle of the engine. Not to far in front of the Turbo. Hope this helped. And I run ATF flued threw my truck, it cleaned it out, also gummed up my filter lol. But that power service stuff they sell, for diesel's, its amazing also I run it all the time.
Old Nov 22, 2009 | 03:05 PM
84 f250 6.9
cool thanks sounds really easy
Old Nov 22, 2009 | 03:37 PM
TheTowingCowboy
It is, just when you take it out it may take a few cranks before it starts cause its refilling the bowl. It may not. Just hope it helps ya.
Old Nov 22, 2009 | 06:11 PM
Brown Falcon's Avatar
Brown Falcon
Seafoam all the way! Love that stuff!
Old Nov 22, 2009 | 06:26 PM
84 f250 6.9
I know man I should be the spokesperson for that stuff I picked up something like 2-4 mpg in my idi after using seafoam
Old Nov 22, 2009 | 07:01 PM
TheTowingCowboy
I will look into this seafoam stuff, sounds intresting.
Old Nov 22, 2009 | 07:31 PM
84 f250 6.9
its awesome you can use it in gas or diesel to clean out the whole fuel system , also you can dump a can in the crankcase run it for 15 minutes and change the oil it will clean most of the sludge out .. rural king walmart and autozone sells it for 7 bucks a can or by the gallon
Old Nov 22, 2009 | 07:52 PM
Brown Falcon
the great thing is it's completely petroleum product... no added alcohols or weird chemicals.
6.whoa
Nov 16, 2016 03:47 PM
kdwellssr
Feb 4, 2016 08:08 AM
scld1354
Jan 25, 2016 07:48 PM
jed1894
20
Nov 6, 2015 11:55 PM
wingedone
6.7L Power Stroke Diesel
Jun 9, 2015 02:41 PM
