egr remove
Old Nov 21, 2009 | 10:22 AM
royboytrip's Avatar
royboytrip
egr remove
1978 f-150-4x4,with 351m,manuel transmission.I took off all the smog stuff,now can i remove the egr and block it with a plate??
Old Nov 21, 2009 | 11:10 AM
fmc400's Avatar
fmc400
MSEE
You should not, and you shouldn't have removed all the smog equipment. Read through this thread:
https://www.ford-trucks.com/forums/903075-egr.html
Old Nov 21, 2009 | 11:17 AM
Blown 331's Avatar
Blown 331
Wouldn't it make sense that if you take away the exhaust gas that is being routed back into the cylinder then that space would now be filled by air/fuel mixture? More air/fuel mixture in the cylinders = more power?
Old Nov 21, 2009 | 03:00 PM
vtjvt's Avatar
vtjvt
I removed everything on my 78, and blocked off the egr, I am running a demon 500 carb and she runs awsome on 85 pump gas, I bumped the timeing up to 12 deg. havent had any negative issues with this setup, with the stock 2150 carb I did get some pinging if I got on it hard but that carb was junk anyway.
Old Nov 21, 2009 | 04:46 PM
Furyus1's Avatar
Furyus1
My truck never had a charcoal canister in it but it did have an egr system at one time - When the PO swapped the engine, he had a new dual exhaust system installed and he transferred the intake manifold (along with egr plate and carb) over from the old engine to the rebuilt shortblock - he blocked the egr port off with a plate... Seems to run just fine without it... There is a vacuum delay valve (at least, I think that's what that is) installed in between the carb and distributor to help with pinging...
Old Nov 22, 2009 | 02:53 AM
royboytrip's Avatar
royboytrip
thanks no smog
thanks for the input on the egr valve,took it off today,man their was so much crap in there was surprised it ran.today one of my friend sold me a 2 barrel holly carb with adapters with gaskets for 20 bucks.sweet deal.will let u know how it runs,remember this is the free trk,so ,well i am smilin
Old Nov 22, 2009 | 10:38 AM
virgojeep's Avatar
virgojeep
From what I have heard from experts on the matter the only way your gonna make it run better without the smog stuff or the egr is to get a different cam. The cam in the 351M is designed for reduced emissions.
reamer
Nov 26, 2015 05:11 PM
damada
6.4L Power Stroke Diesel
Jul 23, 2014 05:57 PM
glb4x4van
Sep 1, 2013 02:20 PM
ScottInTexas
2004 - 2008 F150
Apr 22, 2012 12:49 PM
laynejc
17
Mar 28, 2009 05:46 PM
