Idle grumble
Old Nov 20, 2009 | 05:27 PM
barrycm's Avatar
barrycm
Idle grumble
When I start off or when I let off the throttle I get a loud grumbling sound as I soon as I give it a little throttle it stops. I'm kinda thinking it's the air cleaner vibrating. Any ideas?
1990 F250 7.3IDI
Thanks
Old Nov 20, 2009 | 05:40 PM
PLC7.3's Avatar
PLC7.3
Make sure there is a ring gasket on the intake, there is a rubber one side washer on the hold down and it is tight.
Old Nov 20, 2009 | 08:53 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Also look at the engine block to cab clearance and the exhaust clearance to both the cab and frame.
Old Nov 21, 2009 | 08:14 AM
PLC7.3's Avatar
PLC7.3
Have you done any exhaust improvements, waaaay back there were problems with the OEM exhaust being misaligned on install and a moaning noise was induced.
Old Nov 21, 2009 | 08:28 AM
barrycm's Avatar
barrycm
Thanks All, I think I may have a clearance problem between the firewall and air cleaner. It's hard to get the cover on.
Thanks again, Barry
Old Nov 21, 2009 | 12:07 PM
barrycm's Avatar
barrycm
I found it!! The vaculator valve has a rip in it.
Thanks again I'm posting this in case anyone else has the same problem.
Island'r
Feb 5, 2014 10:44 AM
JethroF250
Dec 24, 2012 08:49 AM
sitdog84
Jun 27, 2011 11:40 PM
Ford_Six
Nov 16, 2002 01:48 AM
jaydeezy
Bronco II
Feb 9, 2001 05:13 PM
