Transmission Fluid Question
Old Nov 20, 2009 | 05:06 PM
Danspeed1's Avatar
Danspeed1
I know similar questions have been asked because I used the search function... but I just wanted to be sure so I will ask once more.... I have a 1985 F350 6.9L Diesel 4x4. Today I changed the transmission fluid and transfer case fluid. I bought Alldata which told me to use either Dexron or Mercon. I imagine that the information I am receiving is from "back in the day." Is Mercon equivilant to todays Mercon V?(5) or was I supposed to use something else?
Also, I am not sure if my rear end is posi or not... If it is not posi, would it hurt anything if I added the posi gear additive (friction modifer)?
Sorry for the seemingly stupid questions, I just don't want to make any expensive mistakes!
Dan
Old Nov 20, 2009 | 05:43 PM
bashby's Avatar
bashby
I believe mercon V is full synthetic, all you need is dextron 3/mercon. It wont hurt anything to add lsd additive to a non lsd rear. You can check the tag on the rear, it will say 3L55 for 3.55 limited slip or just 355 for non lsd.(of course the #s wont neccasarily be 355 unless thats your gear ratio) usually the first # is obscured by the mounting bolt so it may look like L55 or 55
Old Nov 20, 2009 | 07:51 PM
fellro86's Avatar
fellro86
Most stores now just call it dex/merc now. I believe Dex III Mercon is the full proper name, but the labeling is generally just dex/merc. Merc V probably would work, but is overkill. ( yes, full synth.) The additive won't hurt anything if there is no clutches in there. That is all it is for, is to make the clutches grab like they are supposed to.
Old Nov 21, 2009 | 02:23 PM
Danspeed1's Avatar
Danspeed1
Thanks for the tips guys!
I actually went to Walmart and Found Dex Merc III and on the bottle it specifically said it covered all original Mercon Vehicles. Very cool.
Thanks again,
Dan
Old Nov 22, 2009 | 02:25 PM
fsckedagain's Avatar
fsckedagain
I am doing the same thing, do I *have* to drain the torque converter too? Or just filter, gasket and whatever is in the tranny itself?
Old Nov 22, 2009 | 02:27 PM
bashby's Avatar
bashby
Theres a LOT of fluid in the converter, if it has a drainplug I think it's worth the effort
Old Nov 22, 2009 | 08:37 PM
ctubutis's Avatar
ctubutis
I agree, do it right.
Old Nov 22, 2009 | 09:46 PM
Danspeed1's Avatar
Danspeed1
I had an AC Delco Magnet and an "Add a drain plug" lying around... so I added the magnet to the pan and installed the drain plug. I filled it up with new fluid... it will mix with the converter fluid in time... next oil change I will drain oil and the transmission pan, refill both, and call it a day
DG
BAD RONALD
Jun 10, 2013 09:48 PM
AmmoDawg
Jan 8, 2013 09:26 AM
bigred66
Aug 21, 2010 03:38 AM
Proteus503
Mar 7, 2010 07:41 AM
skilife17
1997 - 2003 F150
Apr 26, 2007 03:46 PM
