Electric coolant fan conversion?
Old Nov 20, 2009 | 06:30 AM
Bayer-Z28's Avatar
Bayer-Z28
My truck has been running quite cool... About 150 degrees, or 'O' on the NORMAL Temp gauge..
Anyone ever do an electric coolant fan conversion? I'd imagine I could probably pick up some ponies from eliminating the drag from the fan.
Old Nov 20, 2009 | 08:51 AM
fishforlife2007's Avatar
fishforlife2007
the fan conversion is a fairly common thing on here that i hope to tackle some day myself... what engine do you have, and whats the mileage on the motor? many people use the electric fans out of a taurus due to their high cfm output, and some use the fans out of some lincolns. in my truck i have the 4.9, and after i curved the timing to 12 deg., my temp guage only goes just past the "O", but not quite to the "R". i guess it just runs cool.. and yes you could pick up a lil bit by doing this conversion. i know that some companies offer fan setups that are made for our truck, specifically if you have the 5.0, or 5.8. my suggestion though if you decide to go the route of the electric fan would be to buy a quality electric fan wiring kit from jegs or summit.
Old Nov 20, 2009 | 08:59 AM
lew52's Avatar
lew52
Yeah the e fan will free up some extra HP , so will underdrive pullys....
Old Nov 20, 2009 | 09:05 AM
fishforlife2007
will the underdrive pulleys made for a 5.0/5.8 fit a 4.9, and would you need a new belt?
Old Nov 20, 2009 | 09:12 AM
lew52's Avatar
lew52
I don't know if the pullys will work on a 4.9 or not ...
Old Nov 20, 2009 | 09:33 AM
1966Tbird's Avatar
1966Tbird
i wouldn't put them on a 4.9 since it's not a high rpm motor
Old Nov 20, 2009 | 09:49 AM
quicklook2's Avatar
quicklook2
answer the question of why it is running cool first.
then do search on electric fans because many answers are already on this forum.
Old Nov 20, 2009 | 05:35 PM
Bayer-Z28's Avatar
Bayer-Z28
I've got a 5.0L with 148k on it.. I get plenty of heat in the cab... It ran at operating temp out in the desert of New Mexico, but I drove it back here to CT and it's running really cool here..
My buddy said I could do a radiator shield.. I was going to maybe fab up some 14ga sheet metal strips about 6" wide on either side of the radiator in the front to restrict some air flow in hopes that it will get up to operating temperature. No idea if it's got a 160* t-stat in it or not.. bought the truck used about three years ago.. And I'm thinking about picking up about an 01-04 F150 or F250 seeing as I need the 4WD here in CT for the winter.. No Limited slip rear is just a darn 1 legger... + Snow = PISSED and stuck!!!
I found an 01 F250 Super Duty, 7.3L PS Diesel, 66k miles with a Plow for $19,995. And an exhaust! KBB says $19,625 so it's accurately priced. We had a 6.0L PS in an 05 single cab as a work truck out west and that darn thing MOVED!!!1! Just imagine a darn 7.3L PS pullin a house down! and I can make some money on the plow this winter.. Dunno if I feel like payin $20k for it though.
Old Nov 20, 2009 | 05:52 PM
Elderstarr's Avatar
Elderstarr
Agreed, check why it's running so cold first. T-Stat could be stuck open, or the clutch on your fan could have seized, blowing air constantly through the radiator.
I've done it the e-fan swap... works great. I have to watch the temp if I am towing something heavy, so if you tow lots I would not recommend it.
If you have A/C, use the compressor clutch wire connected to a relay so the fan will kick on for some colder air blowing in the cab. Works great if you're stuck in traffic.
Old Nov 21, 2009 | 08:22 AM
Bayer-Z28's Avatar
Bayer-Z28
^ I was thinkin about that.. I can wire it up easily. Just switched power to the thermostatic switch, then the switch to a solenoid that will route power from a larger wire from the battery to the fan... I'd have to Tee the E-Clutch from the AC in there somewhere.
Just gotta find a thermostatic switch, but even more important is that I'd have to stick it in the block/intake somewhere.
And I never thought of the fan clutch.. Come to think of it, I think is is 'on' all the time. I hear it blowin when I take off first thing in the morning.
Old Nov 25, 2009 | 10:12 PM
Hitokori's Avatar
Hitokori
lol yea the clutch fans are always loud... i think if mine ever locked up i would go about 50mph faster coz all the air its sucking.... F-150 air plane all it would need is wings
Old Nov 26, 2009 | 12:00 AM
l67cooled's Avatar
l67cooled
I just added a electric fan last week. Great improvement. Up here in ND its about 45 to 60 degrees these days and I don't think its ever even kicked in yet, truck runs nicely at operating temp with t stat control. felt a nice throttle difference as well. Although I also did the ignition upgrade and timing bump at the same time as the fan switch.
I used a 95 tauras fan, and a basic fan relay with thermostatically controlled switch. Bent a few pieces of 1/4 aluminum for the brackets.
I would say the fan upgrade is easier than a plug and wire change. IMO Good luck and do it!
Old Nov 26, 2009 | 07:28 AM
rikard's Avatar
rikard
First determine why your truck is running cool. Don't depend on the stock gauge. The thermostat controls the coolant temperature and the factory spec is for 195. When replacing I have used the high flow models from Robertshaw.
I have used electric fans in several trucks, usually to replace a defective mechanical fan, or as an aux fan for trailer hauling. It will draw less Hp than a fixed fan but not a properly operating clutch fan. BTW all of my clutch fans (GM, Mopar, Ford) seem to fail right around 150k to 175k.
Happy Thanksgiving
Thank You Henry
rikard
IHF250fireman
30
Aug 15, 2015 08:07 PM
TheFoum913
Dec 29, 2013 01:11 AM
joe f350
132
Nov 24, 2012 03:36 PM
hotrodfeguy
1983 - 2012 Ranger & B-Series
Feb 26, 2007 08:02 AM
98txexplorer
Jan 28, 2004 10:02 PM
