Steering Column help
Old Nov 19, 2009 | 07:30 PM
F-250 restorer's Avatar
F-250 restorer
Hey guys. I have a '75 F-250 with column shift C-6. I can move the steering wheel up and down, and can see the bushing in the end of the column is shot. Also, the shifting in the column is sloppy and moves freely, rather than clicking into gear.
It is difficult to tell from the LMC truck's diagram which parts I need. Can someone help me out?
Would a '78 tilt column bolt in my '75?
I've also been looking at a floor shifter from Lokar. Has anyone done that conversion?
Thanks in advance.
Old Nov 19, 2009 | 11:29 PM
moose4x4's Avatar
moose4x4
FTE Emeritus
MOST of the time all you would need is an upper bearing or bushing and a lower bearing or bushing. Then put a new shift collar on and that should take care of your problem, unless something on your shift tube itself is worn or broken. Bruce
jeff14346
Jan 2, 2012 05:43 AM
75styleside
Jan 14, 2011 12:29 AM
F-250 restorer
Feb 1, 2010 05:42 PM
F-250 restorer
Nov 19, 2009 09:47 AM
ford-nut
Feb 25, 2005 07:35 PM
