ignition actuator replacement tips or info?
Old Nov 18, 2009 | 05:16 PM
branden.w's Avatar
branden.w
this ignition issue is the last thing preventing me from being on the road, any help?
Old Nov 18, 2009 | 06:10 PM
PLC7.3's Avatar
PLC7.3
Unfortunately that is a fairly involved job as much of the upper column has to be disassembled. I believe if you know a Ford tech who has done it pay him and watch like a hawk........ I would not do it myself personally and I have seen it done 5 times.
Old Nov 18, 2009 | 07:51 PM
yotee's Avatar
yotee
i've done it. it is not fun, but only about an hour or so.
Old Nov 18, 2009 | 08:38 PM
Coolball's Avatar
Coolball
Just a thought it would probably be easier to replace the whole column. I spent this last weekend tearing apart the column of a donor to put the parts in mine (manual to automatic so I had to swap some guts) otherwise I would have switched the whole thing. It's not a horrible job just time consuming. If you can find a used column for a decent price I'd say change it and get back on the road.
Old Nov 18, 2009 | 09:59 PM
crazymike's Avatar
crazymike
i got to do just that about a month ago, i had to come here to even figure out it was called an actuator switch.
its not really all that hard as long as you get another set of hands to help, two minds are better than one.
the only thing i wonder is if someone makes an actuator that isnt made of crap, even aluminum would be better
Old Nov 18, 2009 | 10:19 PM
The_Josh_Bear's Avatar
The_Josh_Bear
"the only thing i wonder is if someone makes an actuator that isnt made of crap"
Amen to that! That piece should never, ever, ever break. Ever. But yet here we all are, talking about having done it or like me, needing to do it! So frustrating that something so important and hard to get to would be made of some garbage metal.
Anywho, I haven't gotten a spare to change it but it looks to me like swapping the column would be a little easier than jumping through all the hoops to change the part, so it's up to you.
branden.w's Avatar
branden.w
i agree, the replacement i got is a cast cheap metal. i dont have the rescources of a pick and pull where i live so i just bought the actuator, guess i just gotta suck it up
Old Nov 19, 2009 | 04:18 AM
Lazy K's Avatar
Lazy K
https://www.ford-trucks.com/forums/8...-actuator.html Have a read through the post here by jas88 on the proceedure.
Old Nov 19, 2009 | 09:42 AM
Taters's Avatar
Taters
I did mine and it wasn't too bad. Tilt steering wheels (which mine is) are a little harder, but still not bad. Here's a good writeup with pictures: http://fullsizebronco.com/forum/showthread.php?t=70454
Old Nov 19, 2009 | 11:30 PM
branden.w's Avatar
branden.w
those were the best and easiest to follow instructions i have seen in a while. thanks alot. and to whoever took the time to do that as well.
westend
Feb 14, 2018 12:32 PM
Randy Ellenburg
May 11, 2017 08:44 AM
mcmain
Aftermarket Products
Nov 7, 2016 03:33 PM
shotgun64
Aug 26, 2015 05:14 AM
Rick_Fury
Dec 10, 2011 10:51 AM
