Sponsored by: Real Truck
ignition actuator
Old Jun 12, 2015 | 06:52 PM
shotgun64's Avatar
shotgun64
ignition actuator
My ignition actuator broke on my 98 f250 SD pickup (work truck).
should I replace the ignition actuator or make it a push start with a ignition toggle switch.
Thanks guys.
Old Jun 12, 2015 | 08:08 PM
ligito's Avatar
ligito
See if this works, for you.
https://www.ford-trucks.com/forums/1...-easy-way.html
Old Aug 26, 2015 | 05:14 AM
pcpotter1023's Avatar
pcpotter1023
This is what I did
I did this on my 1991 F250 (WORK TRUCK) and it was suppose to be temporary but has turned into a somewhat permanent fix, there's a 2 piece trim collar where the column meets the dash, I removed that and got a pair of needle nose vise grips and clamped them to the flat rod you can see on top of the column and now I use the pliers instead of the key to start the truck I just use the key to lock and unlock the steering wheel, a note though, make sure when you pull the pliers back to start it you only pull them back one click if you pull them 2 clicks this puts it in accessory mode and can drain the battery/batteries, and if you ever put it in the shop or let someone else drive it tape the key in the on position because when they go to start it they will try to use the key and turn it all the way around and it can be a bear to get it back to the right position, I learned this the hard way
quakerj
Nov 3, 2017 08:04 PM
Billie_Rae
Jan 31, 2011 04:00 PM
TheProfessorofTOOL
1997 - 2003 F150
Oct 14, 2009 05:53 PM
89MustangGX
18
Mar 1, 2007 03:46 PM
stormyone
Electrical Systems/Wiring
Aug 7, 2005 08:33 AM
