Sponsored by: Auxito
Engine block
Old Nov 17, 2009 | 06:54 PM
riverbottom's Avatar
riverbottom
Engine block
4.6l, V8, 4x4, 97 F-150...Where is the engine block drain plug located? Does this engine even have a drain plug? I looked but did not see a drain plug.
Old Nov 17, 2009 | 08:18 PM
fordmerc's Avatar
fordmerc
What are you trying to drain???
Old Nov 17, 2009 | 09:05 PM
papajoemrt's Avatar
papajoemrt
If you were referring to the anti-freeze drain plug i couldn't find one for the block either so i emptied it from the drain plug on the bottom corner of the radiator.
Old Nov 19, 2009 | 07:38 PM
riverbottom
I was looking to drain the antifreeze from the block but like you could not find a drain plug so I drained what I could from the radiator. What would cause pressure in your cooling system? My top radiator hose stays really hard and when you remove the cap there is excess pressure.
Old Nov 20, 2009 | 07:56 AM
phil6608's Avatar
phil6608
A blown head gasket will cause pressure in the cooling system!
Any other symptoms? Like white smoke or strange smell coming from the exhaust? Oil in the antifreeze or water in the oil?
Old Nov 21, 2009 | 07:34 PM
riverbottom
Been having trouble with engine getting hot. I have changed t-stat, wtr pump, hoses, temp seding unit, cyclinder head temp sensor, radiator, pressure relief cap, and have flushed the radiator. I also did a compression check and leak down test. #7 and #8 cyl were a little weak but within range. I found no leaks. There is no oil in coolant and no discoloration of the oil.
Old Nov 22, 2009 | 08:34 AM
fordmerc's Avatar
fordmerc
When does it get hot? highway? stop and go? Have you checked the fan clutch?
Old Nov 24, 2009 | 06:29 PM
riverbottom
It usually gets hot after driving 7 to 10 miles reguardless of hwy or city. I put a new fan clutch on also. The fan itself is in good shape and the belt is within its specs and working properly. My F-150 has 225k miles. It has been a great truck but I'm starting to think I've come to the end of the road.
mprsox
Jul 28, 2019 01:12 PM
DMTR
Aerostar
31
Jan 31, 2014 06:31 PM
Diesel Don 57
Sep 21, 2010 05:51 PM
wavinwayne
Sep 20, 2005 06:09 PM
pawpaw
1983 - 2012 Ranger & B-Series
Jul 27, 2005 10:59 AM
