Intermitant GPR problem?
Old Nov 17, 2009 | 03:11 PM
TurtleRacing's Avatar
TurtleRacing
PSD Addict
Ok, My GPR works sometimes, sometimes it doesn't, brand new by the way and I was having this same problem with the old GPR. I have an LED hooked up so I know when it is or not. Problem is, I check the large always hot and it's fine, when I check the red trigger wire, it has power when it should but the other large "powered" post doesn't have voltage. But, I can go in, turn the key off, turn it on, it might come on, might not! Never know when it's going to work. I tried grounding the orange wire and it doesn't change a thing.
I'm having a hard time believing it's the GPR. Thoughts?
Old Nov 17, 2009 | 06:07 PM
duck fan's Avatar
duck fan
Because racetruck
Maybe the ground wire has a break in it somewhere??? Just throwing ideas around...
Old Nov 17, 2009 | 06:44 PM
a-rod's Avatar
a-rod
Ive had this exact problem for quite a while, I think it was the junk NAPA GPRs that I was using, I went through 3 of them. I finally up-graded to a Stancor Relay about a month ago and so far so good.
Old Nov 18, 2009 | 06:04 AM
TurtleRacing
PSD Addict
Thanks, I ordered the stancor, hopefully it works. The GPR I installed was the motorcraft unit, I think I paid over $100 from Ford for it.
I don't think it's the ground because I put alligator clips on a wire and grounded it with no luck. I can't help but think it's the GPR.
Old Nov 18, 2009 | 06:16 AM
megawatt00's Avatar
megawatt00
Have someone turn the key while the engine is cold, so the glop plugs will come on) test the two small posts (these feed the coil on the GPR) to see if you have 12V there. The PCM sends a ground signal to the GPR in order for it to come on.
I am having the same problem with my GPR and I tested it like this to make sure that it was a GPR problem and not a signal problem from the PCM. The PCM supplies a ground signal to the PCM. The only reason I knew that my GPR was not working was because the LED that is tied to the load side of the GPR was flickering on me. I did the same and ordered a Stancor from Mouser Electronics.
Old Nov 18, 2009 | 06:17 AM
Smokin''s Avatar
Smokin'
Smokin
Those plastic relays are really chinsey...would be easy to break one on install.
Good luck with the Stancor. Let us know if it solves your problem.
Old Nov 18, 2009 | 08:44 AM
TurtleRacing
PSD Addict
Yep, tried that, got voltage.
I hope the Stancor solves this, it is getting frustrating.
Now, If I jump the 2 large posts that will get me going right?
Old Nov 18, 2009 | 09:07 AM
Mike F250's Avatar
Mike F250
I installed the NAPA GPR two years ago. Shortly after install it did not power the gp's so I jumped with an old screwdriver to get it started. It has not had an issue since then. I have the Stancore relay in the truck as a backup.
Old Nov 18, 2009 | 09:27 AM
Smokin''s Avatar
Smokin'
Smokin
In short, yes. If it works, its proof positive the GPR is bad.
Old Nov 20, 2009 | 07:07 PM
TurtleRacing
PSD Addict
Well, I hate to JINX myself but it sure appears that the Stancor solved the problem. Since it was intermittant I don't know for sure, but every time I turned the key today it was good. Usually it would have definitely messed up by now.
