Sponsored by: Real Truck
ABS Problem!
Old Nov 17, 2009 | 12:56 PM
japps's Avatar
japps
ABS Problem!
Hey guys,
I have a 2002 f250 5.4 gas with 4x4. The problem i am expirencing is when i put engine underload ( like when i go up a hill) the abs light come on and the speedometer goes crazy, then everything goes back to normal untill it happens again. I went to ford and of course they couldnt make it happen and no codes came up. However they suggested that it could be the rear abs/speedo sensor, so i had it replaced. Driving home there was no difference. Has anyone expirenced this problem, and or now how to fix it??
Thanks
Old Nov 18, 2009 | 08:53 AM
japps's Avatar
japps
ttt ttt ttt ttt
Old Nov 18, 2009 | 09:38 AM
V10'nr's Avatar
V10'nr
Abs problem
I changed mine and it corrected the problem. Is the plug area corroded? check it out. Other than that I'm out of idea's.
Old Nov 18, 2009 | 12:51 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Sounds like the rear ABS sensor (VSS)
Old Nov 18, 2009 | 01:33 PM
japps's Avatar
japps
okay when you do replace it does it take a while before it will actually reset its self?
Old Nov 18, 2009 | 06:12 PM
krewat's Avatar
krewat
No, it should fix it right away.
Check for a bad connection.
Also, you should get the ABS system read with a scanner. It should have logged a code, and that code will tell you if it's the rear sensor, or at least, the ABS system THINKS it's the rear sensor which could mean you have a wiring problem, or something loose in the rear end itself.
grafhky52
6.7L Power Stroke Diesel
17
May 28, 2012 08:12 PM
Franco
Jun 3, 2007 11:18 AM
wscodco1
Aerostar
17
Dec 29, 2005 06:13 PM
Rizzle
Electrical Systems/Wiring
16
Sep 29, 2005 05:25 PM
ragoodson5
1978 - 1996 Big Bronco
Jul 25, 2001 06:06 PM
