Aerostar Ford Aerostar
Help Tranny Failure!!!!!!
Old Dec 26, 2005 | 08:13 PM
wscodco1's Avatar
wscodco1
Unhappy Help Tranny Failure!!!!!!
Hey, just wondering out there if anyone else has expirienced this problem.Here it goes I was driving my 93 Aerostar 4.0 AWD it currently has 287,000 miles on it i regularly service this vehicle at the specified service intervals and the vehicle was running great. I am at the light and the van is in overdrive and the light changes and i take my foot off the brake and step on the throttle and without any noise or hesitation the engine stars revving but I'm not moving. The tranny fluid has been flushed about 35,000 miles ago. I don't really conceed that the tranny completely failed because i can shift it in and out of gear and back into park and I can see that the linkage on the trans is moving like it should and I was hoping that someone out there has expirenced this problem and has found a solution!!!!
Old Dec 26, 2005 | 08:54 PM
99f350sd's Avatar
99f350sd
Sure its not something as simple as a major leak cause when it got low enough you go nowhere. Maybe a cooler line rusted or something.
Dick
Old Dec 26, 2005 | 09:04 PM
Kruse's Avatar
Kruse
My '91 did this about 3 months before I retired it. Try taking the shifter out of O/D and putting it down a notch. Mine would then do the 1-2-3 shift, but of you put the shifter in O/D, you would have nothing. It wouldn't even move. Since it was an old beater, I just drove it a couple more months without overdrive. What finally did it in was a head gasket failure.
My money says you had a tranny failure. With that many miles, you are due for something major.
Old Dec 27, 2005 | 02:03 AM
JTHill24's Avatar
JTHill24
wscodco1:
Will it the van move if shifted into any other gear? If not more than likely you have a shot Torque Converter. The Splines will be striped inside it.
Jay
Old Dec 27, 2005 | 12:49 PM
Bear River's Avatar
Bear River
Former ******
The linkage between the shifter and the transmission may be out of adjustment (ei. OD = neutral) Just a possibility. If you can find a transmission shop that does free estimates, that would be the way to go.
Old Dec 28, 2005 | 06:57 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Dec 28, 2005 | 12:35 PM
93nighthawk's Avatar
93nighthawk
Welcome!
Looks like you are covered with JT.
Old Dec 28, 2005 | 02:54 PM
wscodco1's Avatar
wscodco1
Well I highly doubt that it is the torque converter I've owned several cars that had torque converter failure and usually along with the failure there is noises and grinding coming from the bell housing and in this case it is not making any noises and like i said it has fluid and it is good. what i'd like to know is that i dropped the tranny oil pan and I'm looking at what appears to be two solenoids up in there could one or both of these be suspect? I've expirienced several tranny failures and most of them involved some type of catastrofic failure and usually there is loud noises and what not, this just seemed to be unusually quiet
Old Dec 28, 2005 | 02:56 PM
99f350sd's Avatar
99f350sd
Dick
Wow guess what happened to me. Just yesturday I put the 94 into reverse and went backwards . Put it into forward and nothing, rev nothing. I put it into park and then drive and got it to the garage. I had a fluid leak go figure..
Dick
Old Dec 28, 2005 | 03:02 PM
wscodco1's Avatar
wscodco1
Thats great lucky for you, I don't have any leaks and the filter is clean and again the fluid is full.
Old Dec 28, 2005 | 03:15 PM
copper_90680's Avatar
copper_90680
Here is a relevant thread from an Aerostar with half your mileage.
https://www.ford-trucks.com/forums/s...d.php?t=416084
Old Dec 28, 2005 | 07:04 PM
96_4wdr's Avatar
96_4wdr
any movement in 1st or 2nd gear position? any movement in reverse?
bottom half of page
http://autorepair.about.com/cs/troub...a072702a_3.htm
with the high mileage on that tranny, I would recommend a complete rebuild if you are planning on keeping the rig for several more years...replacing only one worn part places extra stress on other worn out parts causing additional failures...will not be a dependable driver until rebuilt.
Old Dec 28, 2005 | 10:27 PM
wscodco1's Avatar
wscodco1
I can shift the tranny through all the gears but i get no movement, period.
Old Dec 28, 2005 | 10:46 PM
93nighthawk
Oye! Time for a rebuild, follow coppers link, and that will walk you through it some.
Old Dec 28, 2005 | 11:24 PM
JTHill24's Avatar
JTHill24
It's a Bad Torque Converter. That is what happened to the 89 I bought.
No Noise, No Grinding. Just wouldn't move. Replaced TC and it runs like a Champ.
Stripped Splines inside the TC.
Jay
