1978 - 1996 Big Bronco
1989 Bronco High Idle
Old Jul 10, 2001 | 11:34 AM
ragoodson5's Avatar
ragoodson5
I have a 1989 Bronco with a 5.0 V8. This truck has been modified with Excell electronic ignition and has a very high idle about 2000 rpm. I have backed out the idle adjustment screw on the throttle body and still cannot get the idle down. Has anyone ever expirenced this problem and do you have any suggestions on how I can reduce the idle?
Old Jul 20, 2001 | 06:54 PM
tite4x4's Avatar
tite4x4
I had an 89 that had that Same problem before I killed it. I'm surprised that I still have hair left. Mine was fluctuating between 1500 & 2100 RPM, tryed the most simplist things first
I Finally replaced all the gaskets on the top end. Upper intake gasket, throttle body gasket, EGR gasket & the valve cover gaskets.
After I did that I had it idleing at 800 rpms. Too much air leakage in the system creates havauc with the computer.
Hope this helps, good luck
Old Jul 23, 2001 | 04:07 PM
8996EBBroncos's Avatar
8996EBBroncos
I had the same exact problem last yr. I tried new stuff to no evail. The problem was cabon build up in the throttle body. you will need to take it off and spray carb cleaner in it and let it soak for a few minutes. Clean all areas of it springs etc. I'll guranntee that'll fix it.
Old Jul 25, 2001 | 05:09 PM
littlejohn's Avatar
littlejohn
I had the same problem with my 89. Took me forever finally discovering that it was the upper intake manifold gasket. Easy and cheap to fix, but surely hard to figure out.
John
Old Jul 25, 2001 | 06:06 PM
Torky's Avatar
Torky
timmer117
Nov 24, 2015 07:06 AM
Papabear78
Dec 15, 2014 10:50 PM
evansz95
Apr 16, 2014 11:29 PM
Bigtex3511
Jun 19, 2013 12:10 PM
gov2mod
Nov 15, 2004 11:41 PM
