manual transmission fluid
Old Aug 5, 2015 | 04:24 PM
Matt4fords's Avatar
Matt4fords
When I called Ford to find out, they told me to use ATF in my 89 f250 5 speed. In my opinion, if you are unsure, call Ford. (Record your call just incase they screw up)
Old Aug 5, 2015 | 10:50 PM
mrollings53's Avatar
mrollings53
What for? Your vehicle is not under warranty. Furthermore Ford isn't liable for what happens to your vehicle even if you follow their instructions. Their liability ended with the owner's manual, and the original warranty.
Old Aug 5, 2015 | 11:49 PM
Matt4fords's Avatar
Matt4fords
It's worked for me in the past when I owned a dodge, they told me something that screwed up my jeep and since the call was recorded (by me) the were liable. I just make sure to cover my butt
Old Aug 6, 2015 | 07:45 AM
WDScott's Avatar
WDScott
Originally Posted by Roy C
I called the Ford dealer and he said his book only goes back to 1988 but that it recommends an ATF for their manual transmissions. What is everyone else out there using for a manual trans? ATF sounds to light.
An easy way to remember what manual tranny takes what:
If it is a cast iron M/T, it will take gear oil. If it is an aluminum M/T it will take ATF.
Same goes for transfer cases.
Old Aug 6, 2015 | 09:05 AM
Diesel_Brad's Avatar
Diesel_Brad
Sounds like someone is sue happy
Old Mar 29, 2021 | 07:54 PM
George5235's Avatar
George5235
I'm getting an 87 F150 this afternoon with the 4spd manual transmission. I called the Ford dealer and he said his book only goes back to 1988 but that it recommends an ATF for their manual transmissions. What is everyone else out there using for a manual trans? ATF sounds to light.
Please forgive me if I ask all the stupid questions but I'm not real experienced in automotive work. This vehicle is a project for me and my son.
i hope this helps i just dug through my glovebox and found this its for an 87
Old Mar 31, 2021 | 08:37 AM
tjc transport's Avatar
tjc transport
i ain't rite
welcome to FTE George.
not trying to sound like an ***, but this thread is 12 years old.
not your fault, it is the fault of the stupid "related topics" line showing way outdated threads and not highlighting original post dates.
but good info.
BlueOvalLover
Oct 4, 2008 06:32 PM
Pugsly
Jan 28, 2007 01:26 AM
brosko80
Feb 18, 2006 10:16 PM
armyguy
Oct 29, 2003 04:01 AM
MarcusBear
Jun 18, 2003 10:48 PM
