Heater question
Old Dec 16, 2009 | 01:22 AM
alamojimmy's Avatar
alamojimmy
Just chiming in with the exact same problem. I have not started to physically look at what could be the problem yet. If you get a no kidding solution, please post it.
Thanks
Old Dec 16, 2009 | 11:03 PM
gearloose1's Avatar
gearloose1
Concur with bpounds.
If the water line into the heater core is hot, and the dash board in diagnostics mode indicate engine warm (at proper temp) and ditto for temp gauge, then it is the heater core / flaps, vacuum motors that is your culprit.
You do need a winterfront if you operate on short trips and cold weather.... tell us your ambient temp.. and so on for more info.
Old Dec 17, 2009 | 12:06 AM
alamojimmy's Avatar
alamojimmy
Went out this morning and checked the Anti-freeze level this morning, sure enough it was low. Way low as it turns out. I put the gallon that I had in my truck in it and the heat came on right away. It was still low so went and picked some up and topped her off. Working like a champ.
Little concerned about the loss of anti-freeze now. I know it will puke some from time to time under heavy load. I did not realize it was almost 2 full gallons worth though. Tuck never got hot but, now I notice the guage barely comes off of the bottom after adding the anti-freeze. Seems like last winter it was about in the middle of it's range...maybe not though.
Anyway, just wanted to post my problem and now the fix for it.
Good luck with your truck and let us know how it turns out.
Old Dec 17, 2009 | 04:26 AM
bismic's Avatar
bismic
Just be aware that significantly low antifreeze levels can contribute to VERY increased corrosion, depletion of the coolant protection, and solids formation.
Certainly the cause of the loss of fluid is the primary thing, but it is just as important to flush the system and fill with new coolant QUICKLY after the leak is found and corrected.
If the leak is in the EGR cooler, it can lead to engine hydrolocking (very expensive) and can contribute to head gasket failure.
68 351 bronc
Sep 30, 2011 05:57 PM
njload
6.7L Power Stroke Diesel
Jan 5, 2011 10:40 AM
bigjimcruising
Feb 9, 2010 09:06 AM
Quinny
1983 - 2012 Ranger & B-Series
Nov 2, 2005 08:42 AM
charlie calcote
43
Dec 23, 2004 06:42 AM
