Injector ID
Old Nov 16, 2009 | 10:43 PM
JTyler11688's Avatar
JTyler11688
Injector ID
My truck is a 1995 F350 PSD from Canada. I bought a stage 1 injector rebuild kit, but I'm curious... I ordered the kit for the 1995 single shot injector, but today when I was intalling my PHP chip, I noticed a tag on a wire group next to the computer that says AB on it. It sounds paranoid, but I think that the CA trucks came with different injectors... is it possible that my truck has different injectors or did all the 95's come with the same? Just curious.
Old Nov 17, 2009 | 12:38 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Your truck should have 'AA' injectors in it since it is a 94'. If it has 'AB' injectors in it then it would have to be running split shot programming. If nothing else you should be able to hear the difference at idle. Just my .02, hope it helps.
Old Nov 17, 2009 | 02:37 AM
joebob3093's Avatar
joebob3093
i dont think the ABs came out till 96. so you should be fine.
Old Nov 17, 2009 | 06:10 AM
Neal 97 250's Avatar
Neal 97 250
Pop one of the valve covers off to be sure. It should say AA or AO on the injector. They are the single shots.
Alsotake a look at the fuel pump. If it has the saucer on it, it may be a Cali version.
Old Nov 17, 2009 | 06:14 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
John,
Your '95 should have come with AA's regardless (actually AO's same thing), the AB CA trucks didn't start till '96. But a quick way to tell is to look in your valley in front of the turbo for this thing.
It's a dampner used on the AB SPlit Shot trucks. If it's not there then you're good.
Otherwise the Kit will still work for the AB's for an overhaul but you cannot bump flow from them, you would ignore the machining instructions for the Intensifier Piston.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
green_95
Nov 28, 2016 11:10 PM
fordguy390
19
Nov 27, 2016 09:24 PM
Shay3171
15
Apr 8, 2016 06:49 AM
hescbr600
May 16, 2006 08:33 PM
Da Mother Ship
Dec 8, 2003 07:50 PM
