Engine Mounts F-100 352 engine 1966
Old Nov 14, 2009 | 09:59 AM
ford66's Avatar
ford66
I want to replace my engine mounts on my 352 engine. I know that the engine needs to come up, but I can't find a place to jack up the engine. What or where is the best way. I've already removed my exhaust manifolds to have them rebuilt.
Thanks
Ford66
Old Nov 14, 2009 | 10:48 AM
Bill W's Avatar
Bill W
Most guy's here will tell you get an engine hoist and lift from the top, (which is prolly the best way) But i put a small bottle jack right on the crank behind the lower pully, it worked for me.
Good luck.
Old Nov 15, 2009 | 08:32 PM
ol yeller's Avatar
ol yeller
small bottle jack on the right side, cross member to engine block. Same on left but have to remove fuel pump.
Old Nov 17, 2009 | 12:34 PM
Customcab's Avatar
Customcab
I recommend using a small 2x4 block of wood against the above mention crank and then the used of a bottle jack or floor jack to ease the engine slightly upwards.
ford66
Mar 6, 2012 03:41 PM
Spyderjohn
Feb 28, 2012 07:56 AM
ford66
Nov 11, 2009 06:41 AM
ford66
Sep 13, 2009 09:06 AM
ford66
Aug 17, 2009 08:09 PM
