66 F100 radiator shroud
did a simple search.... here is what Bill aka(Number Dummy) posted a few years ago.
Quote:
"D3TZ-8146-C .. Fan Shroud
This shroud fits 1967/76 F100/350 352/360/390 with std cooling, xtra cooling and w/ A/C. It doesn't fit the 1973/76 FE Super Cooling radiator.
However it's a BOLT IN for 352 FE 1965/66's. It fits so well, without trimming, you'd think that it was made for these years. I have one on mine."
your welcome.
your welcome.
I don't think the 66 used a shroud, Im sure that someone that knows for certain will chime in and give us the skinny. My 65 didn't have one. When I rebuilt my truck I used a 66 core support and that gave me the option of using just about any radiator up 79. I bought a super cooler or desert cooler as some people call it and used a shroud I had in the shop that came off a 77 model with a 460 that I had parted out some years ago. It was a perfect fit.
did a simple search.... here is what Bill aka Number Dummy) posted a few years ago.
D3TZ8146C .. Fan Shroud / Available from Ford
MSRP: $99.93 // FTE Ford Dealer Parts Dept sponsor PARTSGUYED.COM price: $71.95
1965/66's did not come with a fan shroud, however D3TZ8146C a BOLT IN for 352 FE 1965/66's. It fits so well, without trimming, you'd think that it was made for these years. I have one on mine.
For those unaware: I bought a new 1965 F100 8' Styleside pickup 352/Overdrive in March 1965, sold it in November 2009.
D3TZ-8146-C (replaced: C8TZ-8146-K) .. Fan Shroud / Obsolete
Original applications: 1968/76 F100/350 360/390 / Use with Standard/Xtra Cooling and A/C Radiators / NOT used with Super Cooling Radiator.
Fan shrouds have an ID number at the upper left (drivers) side corner.
D3TZ-8146-C marked: D3TA-8146-DA or D3TA-DA
C8TZ-8146-K marked: C8TA-8146-S or C8TA-S
There are 3 shrouds still available, one of the originals (C8TZ-8146-K), two of D3TZ-8146-C.
C8TZ-8146-K =
GREEN SALES CO. in Cincinnati OH has ONE = 800-543-4959.
D3TZ-8146-C =
FORD PARTS ONLY in Bayamon Puerto Rico has ONE = 787-786-9180.
COLLECTORS AUTO SUPPLY in Oroville WA has ONE = 800-414-4462.
Have the source open the box, to verify that the shroud hasn't broken. Then ask that the shroud be wrapped in bubble wrap before it's shipped.
Most shrouds are fibreglass, fit tight into the box, have a tendency to crack if the box is dropped or tossed around.
Ford obsoleted it 6 months ago. 6/30/2010: It was available when I typed post #4 on this date.
C8TZ-8146-K =
D3TZ-8146-C =
C8TZ-8146-K =
D3TZ-8146-C =
Anyway, I've got a question about when you installed this shroud on your '65. I'm wondering if you think this shroud will work as well on my '66 F100 4x4?
Cheers,
Dion
Thanks Bill. As it turns out, Collectors Auto Supply is actually based in Peachland, BC, Canada, and they've got repros of the D3TZ available. Shipping will be really decent given they ship from Canada.
Cheers,
Dion
Cheers,
Dion
1966 F100 4WD uses the same radiator support as 1965 F100/250 2WD, so it should fit just fine.
When they were still available, a member of this forum bought one, installed it on his 1964 F100 292, said it bolted on w/o a single mod.
str8patina
03-15-2020 10:20 AM
Necromancer
08-23-2015 07:12 AM
rbell14
08-18-2015 11:40 AM
