5.8L piston direction
Old Nov 14, 2009 | 09:22 AM
rockcrawler_101's Avatar
rockcrawler_101
I am rebuilding my 88 5.8L and got the crank in and the front two pistons and tqed them to 45 pounds. Now i cant turn the motor over. I could before by hand. I put the pistons in with the notch forward is this correct? Im putting them back into the same location they came out of just not sure if the notch is facing the right way. I dont want to really yank on it hard if there is something wrong. Im just doing a rering kit on it.
Old Nov 14, 2009 | 09:58 AM
Conanski's Avatar
Conanski
The notch goes towards the front of the motor.
You have the bearings lubricated?
Did you also fit new bearings?
Old Nov 14, 2009 | 10:43 AM
rockcrawler_101
Yeah i used motor assimbly lube. there all new bearing ment for stock nothing oversized.
Old Nov 14, 2009 | 11:14 AM
Conanski's Avatar
Conanski
New bearings.. figured. Did you have the crank and rods checked and machined as necessary? If the motor has some miles on it then some minor machine work will be necessary on the big end of the rods to make them perfectly round again so they don't pinch the new bearing. It doesn't hurt to have the crank checked out as well, it doesn't take much wear to create an oil pressure problem.
Old Nov 14, 2009 | 01:20 PM
rockcrawler_101
yeah i didnt have that done. HMM well back to the machine shop.
Old Nov 14, 2009 | 11:29 PM
Blurry94's Avatar
Blurry94
Having the rods resized is a good idea, but if you're going to do that, then have the machine shop install new rod bolts.
If the crank journals are clean and smooth, in most cases, you can install new main bearings and go. What kind of measuring equipment do you have access to; dial indicator, calipers?
Old Nov 14, 2009 | 11:58 PM
rockcrawler_101
turns out summit sent me the wrong rod bearings. They where .010 under so to think for my app. So hopefully when i get the stock ones it will be good to go.
Old Nov 15, 2009 | 02:46 PM
Beanscoot's Avatar
Beanscoot
Wrong bearings
If you torqued the caps onto the rods with the undersize bearings there is a very good chance that you elongated them. Best to check them over very carefully or get those two, at least, resized.
Old Nov 16, 2009 | 04:03 PM
Kemicalburns's Avatar
Kemicalburns
have your machine shop check everything out and order what you need. this takes all the guess work out of it.
1975FordF250
Apr 5, 2014 09:40 AM
rsheffield
1997 - 2003 F150
Dec 29, 2013 11:25 AM
CaptainIPSC
Mar 26, 2011 08:37 PM
spitfireal
Aug 18, 2006 03:55 PM
loneleader
Jan 19, 2005 01:46 PM
