Inline fuel filter:
Old Nov 11, 2009 | 06:20 PM
BigRed1967's Avatar
BigRed1967
Inline fuel filter:
Hi folks, I just replaced my fuel pump on my 1977 Ford F250 2WD 460ci and the new fuel pump does not have the fuel filter attached to the pump. I want to put in a inline fuel filter; what type do you recommend and where in the fuel line should I put it?
thanks
BigRed1967
Old Nov 11, 2009 | 08:40 PM
projectdagger's Avatar
projectdagger
i have a fram G-2 inline fiter right before the fuel pump, and the second is in the stock location. When i bought the truck the fram filter was on top of the intake manifold right before the carburator. But with the fram filter's the engine heat is litterally bending, almost melting it in a way. Even after moving it underneath the truck, in the location that it is in now. So Next time, i'm gonna switch to reuseable ones from Mr. Gasket
Old Nov 11, 2009 | 08:48 PM
tomcasino's Avatar
tomcasino
Look up this part number at Summit Racing - High Performance Car and Truck Parts l 800-230-3030 (Summit Racing Part Number SPE-2228) and see if this would work for you. Mount it in line after the pump.
Old Nov 14, 2009 | 08:28 PM
projectdagger
thank you for sharing the weblink.. those are just like the ones that we sell at my work
Old Nov 14, 2009 | 11:41 PM
frigerator's Avatar
frigerator
I would stay away from the glass filters. I have heard of them getting broke more then once. I would go with the plastic see through or the metal ones.
Old Nov 15, 2009 | 11:02 AM
projectdagger
i been having a problem with the plastic see throw filter's bending from the engine heat.
Old Nov 15, 2009 | 11:16 AM
4x4 Bart's Avatar
4x4 Bart
I really like mounting a plastic see through filter at the fuel tank. Anytime I am working under the truck, I check it to see how much trash it has collected and replace it often. Plastic should not be used anywhere near an engine.
BigRed1967
Oct 1, 2023 11:00 AM
BigRed1967
Sep 21, 2013 12:17 PM
BigRed1967
Dec 8, 2009 01:33 PM
BigRed1967
Oct 23, 2009 09:14 PM
BigRed1967
Oct 18, 2009 02:27 PM
