2004 Powerstroke Died
Old Nov 10, 2009 | 07:43 PM
haymaker7796's Avatar
haymaker7796
It's a 2004 F-350, 6.0
It just died the other morning. No sputtering, no check engine, nothing. Like someone just reached over and turned it off. Now it will crank, but no start. Any suggestions? No codes show up either.
Old Nov 10, 2009 | 09:17 PM
patrickke's Avatar
patrickke
the admin should take this to the 6.0l forum, but this is what my truck did when the hpop went out sadly enough how many miles you have on it? Plus what mods if any do you have? Have you changed your filters recently?
Old Nov 11, 2009 | 01:29 PM
haymaker7796
108,000 miles with no mods. And I changed the filters about a month ago.
Old Nov 11, 2009 | 07:36 PM
haymaker7796
Anyone? Been reading other posts, but still not sure where to start. If I take the oil filter out and roll over , will it still pump if the HPOP is bad?
Old Nov 14, 2009 | 10:11 AM
jasontrucks76's Avatar
jasontrucks76
I would chime in and say possibly a HPOP or a fuel pump. If the fuel pump goes out it will just die also.
I would post this in the 6.0 section if I were you. There are a ton of great guys there and very helpful.
Old Nov 15, 2009 | 06:43 AM
Maxium4x4's Avatar
Maxium4x4
Welcome to FTE and I have your post moved to year specific. Unplug your ICP and allow it to default.
Old Nov 15, 2009 | 07:06 AM
D8chumley's Avatar
D8chumley
Resident smarta$$
Pull the cap off the upper ff. If theres fuel, I would lean towards HPOP, that is what happened to mine- just died. Crank and no start. Theres a procedure you can follow to narrow it down, I'll see if I can find it. HPOP cost me $2400 at the dealer, out of warranty FWIW. https://www.ford-trucks.com/forums/8...condition.html Here it is
Old Nov 15, 2009 | 12:58 PM
brickie's Avatar
brickie
The 03-04 had some wire chafing issues that will shut off a perfectly healthy motor.There are several places on the injector harness that should be checked.The first is where the harness plugs into the FICM(there is an updated harness with a cover to stop this chafing point)The next is a stud or two on the intake depending on the harness routing.Then between the oil filter housing and EGR valve,then at the alternator bracket.The studs on the passengers side should be checked as well.The FICM has a ground wire on the last stud on the drivers side that can chafe the IPR/ICP wires and must also be checked.First things first is check if the truck has codes.
Old Nov 15, 2009 | 01:02 PM
69cj's Avatar
69cj
If you take the oil filter out the oil will immediately drain back into the pan.
Old Nov 15, 2009 | 01:34 PM
bismic's Avatar
bismic
I think this thread gives you a fairly comprehensive approach at trubleshooting a "no-start". If I missed anything - feel free to add to it!
kelleyboy
Dec 8, 2013 09:18 AM
ramrod99
Mar 25, 2013 02:59 PM
sberube
Escape & Escape Hybrid
Jun 14, 2008 04:37 AM
packmule911
Mar 15, 2005 07:25 AM
