Thermostat Question
Old Nov 10, 2009 | 11:56 AM
outsource77's Avatar
outsource77
Question Thermostat Question
Replacing the radiator, what kind of thermostat (temp., brand) should be installed? My truck is a 76 f100, 2wd, stock I6 300, no air, live in SoCal. Lets hear some opinions, appreciate it. thanks
Old Nov 10, 2009 | 12:20 PM
AbandonedBronco's Avatar
AbandonedBronco
I think stock is 195, but a lot go up to a 210 even because the 300 runs pretty cool as it is. Seems to help with emissions and fuel economy.
Old Nov 10, 2009 | 11:37 PM
F-250 restorer's Avatar
F-250 restorer
I too live in S. Cal. I have a '75 F-250 with a hp 300. I run a 180 thermostat. I like the margin, the cushion it gives when you are right off the freeway and then get stuck in traffic. Water boils at 212.
Anyway, I tried the larger mouth old style thermo's they sell at Autozone, and it was trash. I replaced it with the Israeli brand (Murphy, I believe) they sell at Kragen.
Old Nov 11, 2009 | 09:46 AM
1986F150six's Avatar
1986F150six
F-250 restorer,
Not trying to be argumentative at all, but just for clarification... water does indeed boil at 212F under atmospheric pressure. The boiling point is raised significantly when placed under positive pressure. Under pressure and with the correct mix of coolant / antifreeze, the boiling point may be 250F or greater.
Old Nov 11, 2009 | 02:48 PM
5.0Torx's Avatar
5.0Torx
Originally Posted by 1986F150six
F-250 restorer,
+1. if it boiled in the system, the water pump would start cavitating and youd be up **** creek without a paddle.
Old Nov 11, 2009 | 05:24 PM
4x4 Bart's Avatar
4x4 Bart
The thermostat controls the minimum running temperature, not the how hot an engine can get.
Old Nov 11, 2009 | 05:59 PM
optikal illushun's Avatar
optikal illushun
stant 195*
Old Nov 14, 2009 | 06:56 AM
flipklos's Avatar
flipklos
Gates green stripe 195.
Stant thermos are junk. Thats why wall mart sells them.
Old Nov 14, 2009 | 11:56 AM
satkins1044's Avatar
satkins1044
Roger That!!!!
fordguy2100
Ford Truck Parts for Sale
May 13, 2016 10:37 AM
Resendiz
Aug 4, 2015 02:23 AM
f350on38s
Oct 13, 2010 08:26 PM
Nigel
Aug 28, 2007 10:23 PM
TorqueKing
Aug 12, 2002 10:08 AM
