starter relay question
Old Nov 8, 2009 | 02:54 PM
oldcrow19's Avatar
oldcrow19
Ive been trying to figure out what the "S" and "I" termales are. Ive i was told that the I is for your coil during the cranking it sends extra voltage to help start the motor over. Can any one help me on this. thanks
Old Nov 8, 2009 | 04:32 PM
Franklin2's Avatar
Franklin2
That's correct. The when voltage is applied to the "s", the solenoid will click and connect the two large terminals together, which will apply power to the starter. When the solenoid is activated, 12v appears on the "i" terminal, and on the older trucks this applies a full 12v to the coil + for better starting in cold weather.
Old Nov 8, 2009 | 04:41 PM
oldcrow19's Avatar
oldcrow19
thank you for your reply. I am hoping now this is why i am not getting a good spark to my coil. one last question is the wire that goes from the I termale used with a resistance wire or something?
Old Nov 8, 2009 | 04:45 PM
Franklin2's Avatar
Franklin2
It goes directly to the coil +, ahead of the resistance wire. So it's main purpose is to bypass the resistor during cranking.
Old Nov 8, 2009 | 04:48 PM
oldcrow19's Avatar
oldcrow19
thats my problem then. Thanks again for every thing
Dave58
Dec 2, 2006 12:47 AM
fallingbroken
Jun 25, 2006 04:32 PM
juggerknot
Electrical Systems/Wiring
Dec 12, 2004 12:50 PM
redranger1
32
Jul 17, 2004 11:09 PM
72SportCustomRed
Sep 9, 2003 09:23 PM
