flash??
Old Nov 7, 2009 | 03:49 PM
drzdave's Avatar
drzdave
flash??
hey guys i have 04 6.0 and it had a hypertek programmer that i disconnected as of directions because of the terrible mpg and i disconnected the egr but reconnected it from reading some post on here my question is do i need to anything like disconnect the batters turn lights on and do all that stuff or should be ok cause it seems like i have no low end turbo and when i drive the truck it doesn't move unless it down shifts any thoughts thanks in advance
Old Nov 7, 2009 | 06:05 PM
RescueF250's Avatar
RescueF250
How long did you have the hypertech programmer on there ?
Old Nov 7, 2009 | 07:46 PM
drzdave's Avatar
drzdave
Well it was hooked up when I bought it so I have no idea
Old Nov 7, 2009 | 08:20 PM
RescueF250's Avatar
RescueF250
Honestly get rid of that programmer, drive it stock and see how it runs. If you having issues you might want to get it checked out. As for upgrade I would advise getting yourself a SCT x3. You'll be happy and your truck will thank you as well.
Old Nov 7, 2009 | 09:09 PM
drzdave's Avatar
drzdave
well i disconnected it already thats why i was wondering if i need to do any thing im thinking of doing the vgt reset and see if that helps
Old Nov 8, 2009 | 09:50 AM
drzdave's Avatar
drzdave
Well how do I just flash my back to stock ??
Old Nov 8, 2009 | 12:16 PM
cartmanea's Avatar
cartmanea
Sounds like the turbo veins are stuck, so its not closing down to build boost at low RPM. If this is the case, it will take off once it gets over about 2500 rpm. Make sure the VGT actuator is plugged in (wire going to the turbo). If it is pluggen in, unplug it and see if it runs any different, if not then the turbo is stuck.
Old Nov 8, 2009 | 05:27 PM
drzdave's Avatar
drzdave
well i did the vgt reboot works great now i might do the turbo cleaning for peace of mind later on thanks though
Old Nov 8, 2009 | 06:14 PM
cartmanea's Avatar
cartmanea
What's the VGT reboot you're referring to?
Old Nov 8, 2009 | 09:20 PM
drzdave's Avatar
drzdave
Um I found it on here somewhere I printed out so I can tell u more monday
408 Torquer
Nov 27, 2014 07:34 AM
A/Ox4
Jul 8, 2012 10:52 PM
gsxr10001
Mar 31, 2012 11:52 PM
rolltide3006
Jul 24, 2011 12:37 PM
jasonwf350
Jul 10, 2006 06:07 AM
