Thanks you guys for posting up these results, i appreciate it! I hated to run off like that but the situation sounded serious (and somewhat was).
So #2 definitely sounded a bit weak. 2 & 8 are usually cps faulty injectors correct? I'm thinking an ohm check of my cps to the ecu may be needed. However now that 1 is not kicking out on the contribution i'm thinking UVCH since we are on the same bank.
Not a problem, as Tom said I hope everything is OK.
Originally Posted by mndiesel
Let me know if Mon or Tues works. I don't mind helping so just let me know what works for you, Osceola is only 45 minutes away and helping gives me something to do. We will have to have a gtg in the next week or two , my front wheel bearings are getting louder!!!
How's the back feeling after being in the cold again? Looks like I better get the shop heated sooner rather than later.
Well now i've noticed if it rains the truck will randomly drop at least 500rpm like it dies, then come back to life. Its very sudden and jerks you quite a bit. Any ideas here? Its not even like downpouring rain... just light and steady.
Mike & Tom let me know when you'll be available sometime so we can finally do a few more tests and get this dang thing figured out!
On another positive i think my steering box is going out... have a nice binding once in a while.
[quote=
How's the back feeling after being in the cold again? Looks like I better get the shop heated sooner rather than later.[/quote]
The back was still sore but not as bad as the first gtg night.
My daughter started hockey so its hit or miss for me. SHe has a game Saturday at 5pm but I am free in the morning that day? Let me know. Maybe we can have a gtg at Nike's and we can try to grease my front wheel bearings!!!!!!!
I have another turkey day celebration on Saturday at my sisters so sat. morn i wont be around. So i guess whenever after that, maybe i should start my random postings so i can get PM's. haha.
Well i swapped #2 and #4 injectors last night with different but sort of the same running condition. Still shakes but not at the same rpm as before, got me thinking its just a bad injector. Looks like the UVCH had the keepers in there already but i did the 25 cent mod because it seemed like a tighter fit. Now however i have a hard code showing up, just need to check it out. Buzz test would be nice also.
Well turns out it was just a bad injector. HPO valve went bad.... wish i could've known that from the start! Called up DPS and got it fixed for cheap and they turned it around in a day. Absolutely outstanding guys over there.
See you guys Sunday at Mikes! Should have her ready to go.
