Help! Misfire/stutter
Old Nov 10, 2009 | 10:17 PM
Flyin5's Avatar
Flyin5
Forgot to mention that yes it starts little harder.... not a whole lot though. Had it die on my coming home today... while it was good and warm.
Old Nov 10, 2009 | 11:21 PM
Flyin5's Avatar
Flyin5
Just took out the chip and ran it stock with the same stutter result, then swapped ecu's with the same result also.
Gave it a good rev and the smoke smells funny. Not like a diesel smell, smells like a little oil in the mix?
Old Nov 11, 2009 | 06:24 PM
F350-6's Avatar
F350-6
I would have expected the truck to run noticeably worse after the chip was removed.
Any luck getting those rotational velocity numbers?
Old Nov 11, 2009 | 10:09 PM
Flyin5's Avatar
Flyin5
No luck so far... probably not until next week when deerhunting is over.... this is killin me!
Old Nov 14, 2009 | 07:35 AM
Ford79's Avatar
Ford79
I might be able to get you a scan sooner than next week, let me know and I can make a call.
Old Nov 14, 2009 | 10:45 AM
Flyin5's Avatar
Flyin5
that would be great! i'm throwing a hard code now and its running even worse. seems like all cylinders shut off for a split second while cruising. Its really random.
Old Nov 16, 2009 | 10:36 PM
Ford79's Avatar
Ford79
Here's what Tom(mndiesel) came up with tonight with AE. No chance to run the rotational velocity test. Mike (Flyin 5)had to leave early.
P0266 Cylinder 2 contribution/balance fault, power cylinder, valve train or injector problem, circuit
P0284 Cylinder 8 contribution/balance fault, power cylinder, valve train or injector problem, circuit
#2 was also Low on the buzz test.
I found the description for the codes on another site.
Old Nov 17, 2009 | 12:20 PM
mndiesel's Avatar
mndiesel
#2 was definately alot softer tone on the buzz test. Does anyone have a better description of those codes. Any ideas would help.
Old Nov 17, 2009 | 07:12 PM
Flyin5's Avatar
Flyin5
Thanks you guys for posting up these results, i appreciate it! I hated to run off like that but the situation sounded serious (and somewhat was).
So #2 definitely sounded a bit weak. 2 & 8 are usually cps faulty injectors correct? I'm thinking an ohm check of my cps to the ecu may be needed. However now that 1 is not kicking out on the contribution i'm thinking UVCH since we are on the same bank.
Old Nov 17, 2009 | 09:41 PM
mndiesel's Avatar
mndiesel
[quote=Flyin5;8148349]Thanks you guys for posting up these results, i appreciate it! I hated to run off like that but the situation sounded serious (and somewhat was). quote]
Mike don't worry about it hope everythng is OK. Maybe later thi week or weekend we can do the ret of the tests and do si=ome live mkonitoring to get that truck fixed.
Old Nov 17, 2009 | 09:48 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Damn Tom, kudos to you for the help but is your keyboard failing?
Old Nov 17, 2009 | 10:16 PM
Flyin5's Avatar
Flyin5
[QUOTE=mndiesel;8148983]
That would be great. I know i am going out of town for hunting next weekend but let me know when you plan on coming around next.
Thanks for all your help!
Old Nov 17, 2009 | 10:33 PM
  #28
Hiflyer746's Avatar
Hiflyer746
Just for grins, Pull of the oil cap off while running and see what it looks like.
Timmy
Old Nov 18, 2009 | 01:14 AM
  #29
mndiesel's Avatar
mndiesel
I am on some good pain pills, actually my laptop has some keys that are on the way out. Thanks for posting I will keep an eye on that.
Old Nov 18, 2009 | 01:20 AM
  #30
mndiesel's Avatar
mndiesel
[quote=Flyin5;8149104]
Let me know if Mon or Tues works. I don't mind helping so just let me know what works for you, Osceola is only 45 minutes away and helping gives me something to do. We will have to have a gtg in the next week or two , my front wheel bearings are getting louder!!!
