Sponsored by: Real Truck
v-10 vaccum problem
Old Nov 6, 2009 | 03:56 PM
songdawg's Avatar
songdawg
Question v-10 vaccum problem
Hey does anybody know what would cause my 2000 v-10 F-350 to create vaccum in the crank case ? I have changed the pcv.
Thanks
Old Nov 6, 2009 | 08:08 PM
1ViciousGSX's Avatar
1ViciousGSX
A vacuum in the crank case is not a bad thing. There should be some. Unless it's excessive.
Old Nov 6, 2009 | 08:46 PM
FireMe's Avatar
FireMe
What exactly is happening that makes you think there is a problem?
The only way I can think of excessive vacuum occurring is if the fresh air PCV hose was plugged.
Jay
Old Nov 7, 2009 | 02:29 PM
songdawg's Avatar
songdawg
vaccum v-10
well it crushes vac lines & when I remove the oil cap it releases a large amount of pressure ( vac negative ) . thanks guys
Old Nov 7, 2009 | 02:35 PM
1ViciousGSX
There should be some type of breather hose/filter to allow clean air into the crank case. Check that for collapse or plugging.
Old Nov 9, 2009 | 03:14 PM
songdawg's Avatar
songdawg
Thanks ill try it.
sflem849
Jan 11, 2013 07:47 AM
guliver
Escape & Escape Hybrid
Mar 19, 2011 11:17 PM
T_Moss
Modular V10 (6.8l)
Aug 12, 2005 01:40 PM
ceetwarrior
18
Nov 13, 2003 10:56 PM
plumr
Mar 16, 2002 11:54 AM
