Modular V10 (6.8l)
Vaccum Leak
Old Aug 11, 2005 | 10:54 PM
T_Moss's Avatar
T_Moss
Unhappy Vaccum Leak
What is the best way to find a vaccum leak?
I've never had issues with vaccum lines on my previous fords, but it's bogging when I stomp on it. And my AC moves to the defrost when it's under exceleration.
I ve herd of the fish tank hose trick, (it worked to test my EGR valve) but how do you tell where or which vaccum line is leaking coming off of the tree.
I can't see any signs of cracks or cuts.
Help..loosing that V10 power...must have it back!
Old Aug 12, 2005 | 11:47 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
The big vacuum leak that always pops up is the dreaded PCV elbow - follow the line from the PCV back to the throttle body, usually it cracks at the elbow.
Do you have ESOF?
Old Aug 12, 2005 | 01:12 PM
T_Moss's Avatar
T_Moss
Yea, I had to replace that little devil about 6 months ago. Hard spot to get to right under that billet. That elbow split right down the middle.
This leak is much smaller than that was. Can't hear any sucking noise like when the elbow split. And I am not pulling any codes. It just hesitates when I get on the gas moderate to heavy, then I can lay off and get back on it and it is fine. Anything over 2K RPM on the highway or going up a hill and the AC switches to the defrost vents.
I do have EFOS.
I am thinking it is one of the lines coming off the tree. I have never worked on those before, so any pointers will help. I am going to work on it this weekend.
Thomas
Old Aug 12, 2005 | 01:40 PM
krewat's Avatar
krewat
I think there's a one-way valve in the vacuum line going to the heater box. That valve may be leaking, causing the heater box to lose vacuum when you're on the go-pedal.
Check it out. Should be a little round thing (like the size of a quarter but thicker) inline to the heater box.
On edit: Did you clean the MAF? That may be causing the hesitation.
F100XL300I6
New Member Introductions
Apr 26, 2014 07:53 AM
Nally427
Aug 19, 2013 07:01 PM
KEO
Dec 19, 2008 10:50 AM
Flame Out
Jan 23, 2007 09:12 PM
Katt
Apr 13, 2000 07:54 AM
