ruff running when cold
Old Nov 4, 2009 | 04:51 PM
rougerocco's Avatar
rougerocco
My 04 in running really bad and ruff when cold. Even after the temp. gauge moves up. I plug it in and it runs fine. No problem starting, runs like it is missing, temps under 50 it is doing this. I am also not getting any heat unless I run above 1500 rpm, even if it is warmed up. Don't know if the two are related....
Winter in coming in Michigan fast this year looking to get it fixed. please help!
Old Nov 4, 2009 | 05:52 PM
2000 roadking's Avatar
2000 roadking
No Heat
I don't know if this is true,but I had to replace water pump on a 05 F350 and when I was done it had no heat, I checked everything I could and then sent it to dealer they said I had installed a aftermarket water pump and the pump ran dry and messed up the front cover???? Anyway long story short after I produced the receipt for the FORD pump and some other parts they covered it under warranty. I never did get to see any old parts [I guess because I did not pay them a dime] But everything worked and I never sent another vehicle to them! You really need to give more info on your truck ie service date, oil weight ,year model etc.
Old Nov 4, 2009 | 06:59 PM
msgtg's Avatar
msgtg
It's pretty tough to help because (1) you didn't give us enough info and (2) you contridict yourself.
First, how many miles on the truck...are you the only owner? Second, you say you plug it in and it runs fine...but then you say it is missing.
I live in WV, I plug mine in anytime the temp drops below 40. Remember your oil turns to the consistancy of molassas when it gets cold...unless you're using a syn oil. By plugging it in, you keep your oil from becoming thick...you're also taking a lot of strain off of your starter and batteries too.
How long are you letting yours warm up? I start mine when I let the dogs out in the morning. I unplug it and go back in the house to load my pockets and grab the laptop. Mine runs for about 5 minutes before I jump in and drive off. The air isn't hot but it certainly isn't cold. Within another 5 minutes, I have to turn the heater down before it runs me out of the truck.
Joe
Old Nov 4, 2009 | 08:06 PM
rougerocco's Avatar
rougerocco
sorry - I have 135,000 miles I have owned it since 15,000 miles.
if I don't plug it in it runs bad. I never had to do it before! The past few years below 30 I plugged it in. Now if it below 50 it runs bad.
On the no heat issue- I ran it for hundred miles, then after driving at low speeds for about half an hour I had cool air coming out of the vents, until i revved the motor.
I am running 5W40 Amsoil in it if that helps...
Old Nov 4, 2009 | 09:06 PM
BobsF350's Avatar
BobsF350
glow plugs on the cold start heat not sure where in mich are you iam in sterling heights
Old Nov 4, 2009 | 09:40 PM
rougerocco's Avatar
rougerocco
Trenton- BobF350
Old Nov 5, 2009 | 12:25 AM
topdrive's Avatar
topdrive
have you ever had any puking issues my 03 was doing this last winter no heat under 1500rpm in my case it was cracked heads i put new heads arp studs and an egr delete on and problem solved good luck
Old Oct 4, 2010 | 05:40 PM
wingnutt2420's Avatar
wingnutt2420
I had a similar problem. It had no power when it was cold and ran ruff. The problem was 3 injectors died and the truck was running only on 5.
Old Oct 5, 2010 | 03:39 PM
Mark Oomkes's Avatar
Mark Oomkes
Do a search, there are about 3 million threads on this problem.
Most will tell you to reflash, FICM, etc.
But on my trucks it has always been bad injectors.
I currently have 3 6.0's and all run rough. Between just 2 of them, I have had 9 injectors replaced. Total of 130K miles, give or take. My guess is I have at least 9 more between all of them, but they are all out of warranty now. And they all have had synthetic oil for a couple years.
Old Oct 5, 2010 | 10:14 PM
bismic's Avatar
bismic
This is an old thread that has been resurrected for some purpose (not sure what), but what the heck .....
Get the most recent flash, install the updated fuel pressure regulator spring, monitor your fuel pressure, use OEM fuel filters (Racor or Motorcraft or International), do your best to get good quality fuel, use a cetane boost additive, keep your oil clean, and your injectors will be very reliable (in the vast majority of cases).
Old Oct 6, 2010 | 07:30 AM
Mark Oomkes
Axed this in the other thread, but aren't Fram and Motorcraft filters made by the same company?
JSMMV
1983 - 2012 Ranger & B-Series
Feb 23, 2014 05:27 PM
old five string
Oct 31, 2012 09:04 PM
mellowyellow440
Dec 28, 2009 07:34 PM
remmers
Nov 30, 2003 01:02 PM
