hard shift into 3rd
Old Nov 4, 2009 | 07:34 AM
matt0588's Avatar
matt0588
hard shift into 3rd
I have a 2000 F250 SD 7.3 auto 4WD 96Kmi stock.
recently my truck is hitting 3rd pretty hard. does my truck learn driving habits and if so, can I disconnect the batteries for a while and allow it to go back to factory specs to see if this helps? it generally hits hardest under light acceleration. thanks for any help
Old Nov 4, 2009 | 07:50 AM
Pocket's Avatar
Pocket
The PCM is about as dumb as a brick, and doesn't have a learning curve for the transmission. So disconnecting the batteries won't change anything.
How long have you had your truck? Reason I ask is that sometimes that shift into 3rd, under a certain speed and throttle position, will also lock the torque converter at the same time. What happens is you feel the shift and lockup, and it's a much harsher upshift than normal. If you aren't used to it, then it feels weird. Ford's shift strategies aren't exactly the best on these trucks.
If you've had your truck for a while, and it's doing something new and completely different, then give us a few more details.
Old Nov 4, 2009 | 08:17 AM
matt0588's Avatar
matt0588
I have had it since new. 3rd has alway been different. sometimes smooth, sometimes like its going into neutral for a second then into third, sometimes it like a double shift and the rpm's drop. I use my truck for work and it is mostly in town miles. changed trans fluid and filter at 30k and 60k including draining the TC. when I have time it is ready for another service. this time of year I am doing service calls at 20-25 houses a day. need to go to work, I will check response later. Thank you
Old Nov 4, 2009 | 03:07 PM
flatbeder's Avatar
flatbeder
subscribing
Old Nov 4, 2009 | 03:21 PM
rbaker6336's Avatar
rbaker6336
Do you have a chip in it?Mine has had some really goofy shifts since I put the DP in it
Seems it goes from 2nd to 3rd lock among other things
Old Nov 4, 2009 | 05:13 PM
Pocket's Avatar
Pocket
Sounds normal to me. It's common to see the 2-3 shift/TC lockup happen at the same time under certain conditions, which makes the shift act funny and you get that "double shift" feeling. It's based on TPS and vehicle speed.
On edit: I see that you're in Littleton. If you have any questions, I would be happy to show you what's going on with your truck.
Old Nov 4, 2009 | 05:16 PM
Pocket's Avatar
Pocket
Jody has made some changes to the shift strategy with his current tunes. Might want to talk to him about adjusting your transmission shift strategies.
Old Nov 4, 2009 | 05:34 PM
rbaker6336's Avatar
rbaker6336
It really needs something or I am going back to stock.Ive been running in the stock setting for a few days and started liking my truck again
It is really a pain to drive in either tune
Old Nov 4, 2009 | 05:57 PM
matt0588's Avatar
matt0588
I assume the TPS is the throttle position sensor. I noticed today that different amounts of throttle have a lot to do with the shift. constant acceleration and the shift is fine, letting off at the shift point and it hits pretty hard, and under load it's like a hesitating shift and then it just bogs down. It's almost like its shifting too early under a load and too hard under light acceleration. does the ECM have different parameters for shift points or are they set in stone? I have heard of shift kits ( for a lack of the actual name), do they change the shift points?
Old Nov 4, 2009 | 06:15 PM
SpringerPop's Avatar
SpringerPop
Your line pressure modulator valve may have gotten excessively worn. It's caused by a steel valve riding in an aluminum body.
Google "Sonnax valve". It's cheap, and may fix your problem.
http://www.puredieselpower.com/catal...-kit-p-85.html
It's a common problem with high-mileage 4R100's, and why Sonnax developed the kit.
It's what I used a few years ago.
It's a quite noticeable improvement, but I have nothing but stock to compare it to.
So, for what it's worth, I'm still quite happy what it did for my shifts.
Pop
Old Nov 4, 2009 | 06:56 PM
flatbeder's Avatar
flatbeder
Marv how hard was it to do this install? thanks for that post i will be in the market for that PMV...just wondering how the install went?
Old Nov 4, 2009 | 07:05 PM
SpringerPop
It took me about two and a half hours, maybe three.
It's just like doing a pan-drop oil and filter change, and add about 45 minutes to R&R the tricumulator.
Be sure to have an appropriate-range inch-pound torque wrench on site. The Tricumulator body can warp from over-torqued bolts/nuts.
With the re-usuable pan gasket (yes, re-use it), you also want to properly torque the pan bolts.
Be sure to clean the ring magnet around the drain plug, too.
It's a good time to change the filter (be sure to get the old o-ring out of the pump inlet if it doesn't come out with the old filter).
The most important thing, besides a large-enough drain pan, is a plastic tarp put down. The job gets messy with oil dripping.
Don't do the job on a windy day, as dust and dirt will get blown up into the trans, and you gotta' keep everything spotlessly-clean! CLEAN! KLEEEEEN!
Pop
Old Nov 4, 2009 | 07:20 PM
flatbeder's Avatar
flatbeder
Thanks Pop...my tranny has the same simptoms and I'm gonna see if PaysonPDS could help me with this
Old Nov 4, 2009 | 08:16 PM
Pocket's Avatar
Pocket
Shift kits only adjust pressure to firm up the shifts, but do nothing to address the actual shift points, or when the torque converter locks up. Shift points and converter lockup tables are all defined in the PCM.
Shift pressure is also addressed in the PCM. However, those values are pretty low in stock tuning. Those harsh shifts you feel are the combination of an upshift and the torque converter locking at the same time, resulting in the engine bogging down at low RPM's.
Just by reading this post, it sounds like you're are not happy with the stock shift points and torque converter lockup strategy. I can definitely relate, as I hate the stock shifting too. But I think you've figured out a little bit about how the TPS and vehicle speed relate to shifting. Paying attention while driving like you did really helps to understand what's happening.
lvin4jc
16
Jan 15, 2017 10:00 AM
VaSpoof
Oct 7, 2015 10:35 AM
william16339
Jun 28, 2015 02:02 PM
scrobbie
Jan 18, 2014 06:12 PM
ackeiyword
2009 - 2014 F150
Jan 9, 2011 01:32 PM
