1978 - 1996 Big Bronco
lifter stress
Old Nov 3, 2009 | 07:15 PM
60@F350's Avatar
60@F350
4wd Low
lifter stress
'92 w 351W EFI. Had to pull intake housing to get right valve cover off chasing a clicking noise. found one rocker arm loose. Rockers are in pivot saddles. Torqued all 8 of them to 23 per Haynes manual. Got it back together and noise did not change so, I am deducing that the lifter(s) need replaced. My Q is... will I do damage driving two more weeks before I have time to tear in again?
Old Nov 4, 2009 | 04:48 PM
Kemicalburns's Avatar
Kemicalburns
if your easy on it you will probably be fine. sounds like you have a couple stuck lifters. its best to change all of them at once. just know that if you prolong this you could bend a push rod which may cause other damage
Old Nov 4, 2009 | 08:03 PM
60@F350's Avatar
60@F350
4wd Low
thnx
thnx dude!
Oldschool2888
Jul 22, 2016 12:23 AM
jrockdiddy
20
Apr 12, 2016 10:44 AM
billyrayf150
Feb 13, 2016 11:50 AM
Fireman04
Modular V8 (4.6L, 5.4L)
Oct 6, 2015 09:26 PM
jcmiller
Jan 20, 2005 12:55 AM
