CCV MOD ????
Old Nov 1, 2009 | 07:18 PM
bakerbuilttracks's Avatar
bakerbuilttracks
CCV MOD ????
ok so i did my ccv mod the other day which i bought from clay. man he shure did a great job putting that kit together. so i got the stinky smell now. i was thinking bout extending the tube back to the rear but i looked on guzzles and they showed how to build an oil trap which may cut down on alot of the smell. befor i waste my time building one i was checking to make shure that thing is going to be safe. or in other words not restrict the blow off and build up too much pressure..... and cause a leak or harm anything. so would this be a good thing todo or has anyone
done anything diffrent.
Old Nov 1, 2009 | 07:22 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
What kind of oil are you using? I had the same problem until I switched to Rotella T... Just a thought.
Old Nov 1, 2009 | 07:31 PM
Bigcat350's Avatar
Bigcat350
I run my hose to the back axle. I can see the exhaust come out from under the rear fender some time but rarely smell it. I use Rotella
Old Nov 1, 2009 | 07:47 PM
clintbonnie's Avatar
clintbonnie
I would be careful in running the hose back to the rear axle not to create a low spot (like a "P" trap below a sink) that would collect oil and block off the air passage to the exit.. Just run the end of the hose into a plastic bottle with vents in the lid to collect the oil.. Mine works great.. I empty mine about once every 2 months..
Old Nov 1, 2009 | 07:53 PM
guzzle92's Avatar
guzzle92
Even with a trap you get the stink.
Old Nov 1, 2009 | 08:08 PM
Izzy351's Avatar
Izzy351
The only way to get rid of the stink and not get oily boots is to build a trap, but then route it back into the intake in the stock manner. I'm about to do this myself. Just because I feel like getting rid of the cloud that comes out from under the back of my truck. I have it run to the back axle and don't have an issue with smell, just tired of the cloud. LOL
Old Nov 1, 2009 | 08:20 PM
Bigcat350's Avatar
Bigcat350
I am thinking of doing the same thing Joe. Just to get rid of the cloud
Old Nov 1, 2009 | 08:28 PM
Pocket's Avatar
Pocket
Me too.
I've had my CCV mod for over 5 years now venting to the driver's side wheel well. It has never once given me issues, but after 5 years, I'm tired of catching a whiff every now and then.
Cross my fingers, I might have time this week to finally build my CCV trap, and re-route it back to the intake.
Old Nov 1, 2009 | 08:49 PM
bakerbuilttracks
im running rotella t great options guys im aware of not making a "p" trap in my line like plumbers say "**** falls down hill" haha but the smell and the cloud i would like to get rid of fo sho.... but from what ive read it ant gunna happen.. but is the trap safe and dose it help any?????
Old Nov 1, 2009 | 09:00 PM
gasgrunt88's Avatar
gasgrunt88
I switched to Rotella Synthetic and I still get alot of vapor. I really don't get any stink, but plenty of vapor.
Old Nov 1, 2009 | 09:03 PM
guzzle92's Avatar
guzzle92
The only thing the trap will do for you is to eliminate the periodic oil drips on the driveway from an open CCV hose.
Depending on the amount of blowby you have, some have more drips than others.
Old Nov 1, 2009 | 09:39 PM
bakerbuilttracks
10- 4 well a few of yall were talking about re routing it back into the intake to rid the smell. how are you palnning on doing that and not getting any oil in your ic boots etc. i know the ccv mod fixes that prolbem but if you run it back in the intake whats the point of the mod????
Old Nov 1, 2009 | 09:43 PM
Bigcat350's Avatar
Bigcat350
You still run it down to a trap and then back to the intake.
Old Nov 1, 2009 | 09:54 PM
bakerbuilttracks
well i would be very intersted in how you would go about doing this. really on building ur trap where it would mount and how it would all tie together.
Old Nov 1, 2009 | 10:43 PM
CLStewart144's Avatar
CLStewart144
OK.. So now I am kinda mad.... I just spent ALL day today taking all my pipes and I/C out and making them spotless, and now you guys are talking about clouds and stenches when I do this mod... Just how bad is the smell?? and also what kind of "cloud" are we talking about?? I don't want to drive around looking like Linus off of Charlie Brown....
