Air Cleaner Temp Sensor
Old Nov 1, 2009 | 07:14 PM
79FordBlake's Avatar
79FordBlake
Where would I find one for a 73 F100 302? Ive been looking around with no luck. LMC has one but it says its for 75-79 trucks.I had two setting around but they don't work either. Any place to get a new evap canistor hose also? Thanks.
Old Nov 1, 2009 | 08:16 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Is the hose your refering to the one that goes from the canister to the air cleaner?
Old Nov 1, 2009 | 08:29 PM
79FordBlake
Yes. The problem I am having with the air cleaner temp sensor is it is not closing the metal flap. So the carb is always pulling in air from the preheater duct. I have it unpluged and blocked off right now so it will pull air from the fresh air duct.
Old Nov 1, 2009 | 08:37 PM
mikeo0o0o0's Avatar
mikeo0o0o0
I don't know about the sensor but NAPA has a replacement tube listed in their emission catalog. Its 3/4" by 3' long, corrugated aluminum tube. I just bought one a couple of months ago. The finish and color aren't like the original but unless you're going for originality, it will work fine.
One question. Are you sure it's the sensor and not the vacuum actuator?
A quick check is to hook the hose from the actuator to a vacuum source and see if it opens.
Old Nov 1, 2009 | 08:41 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Here's what the tube looks like. It's still coiled up like when it's in the box.
Old Nov 1, 2009 | 08:47 PM
79FordBlake
Yep, already did that test. Thanks for the info. Ill check by Napa, I have one close by.
Old Nov 1, 2009 | 08:54 PM
mikeo0o0o0's Avatar
mikeo0o0o0
I don't know if it will help but here are the original part numbers:
D3ZZ-9E607-A temp. sensor
D7AZ-9D612-C actuator
Old Nov 1, 2009 | 09:00 PM
79FordBlake
Thanks. I wonder if it would throw the guys at Napa for a loop if I gave them these numbers? lol.
Old Nov 1, 2009 | 10:13 PM
Kennewick's Avatar
Kennewick
I just picked up a full 302 aircleaner with all the goodies for 10 bucks at the junk yard Sat. I am heading out there again next Sat. Let me know if you have not found one yet. Ive been making a few improvements, Heh heh.
Barnfind79
Dec 10, 2015 02:46 PM
iwals
Sep 13, 2015 03:47 AM
79Ranger250
May 9, 2014 08:00 AM
Maverick1978
Mar 30, 2014 08:22 AM
79aldean
Feb 22, 2014 05:37 PM
