Bad ICP Sensor?
Old Nov 1, 2009 | 05:25 PM
90F250351's Avatar
90F250351
Bad ICP Sensor?
I have an 05 F-250 PSD...My check engine light is back on again. I recently had some work done on the truck at the local dealership the last time the engine light came on about a month ago. I had a low injector control pressure code last time. I havent scanned it this time yet this time. I also notice alot of blue smoke when I first start the truck in the morning only along with a long crank. Is that normal? Is it because the weather is getting colder? Also noticed a loss in power. Any suggestions before I go back to the dealer and have to pay another $100 co-pay ?
Old Nov 1, 2009 | 05:42 PM
bismic's Avatar
bismic
What did they replace/fix last time?
Remember - under emissions warranty you will not be charged for labor, diagnosis, or parts for any emissions control device or system for 100k (ie no $100 deductible):
Air flow sensor
Air Fuel Feedback control System and sensors
Cold start enrichment system
Electronic engine control sensors and switches
EGR system
Exhaust manifold
Fuel Injection System
Intercooler Assembly - Engine Charger
Power Train Control Module
Turbocharger Assembly
Also covered by the two emissions warranties (Emissions defect warranty and Emissions performance warranty):
All emisssions-related bulbs, hoses, brackets, tubes, gaskets, seals, belts, connectors, non-diesel fuel lines and wiring harnesses that are used with components on the list above.
Old Nov 1, 2009 | 05:45 PM
90F250351's Avatar
90F250351
they replaced the STC fitting and the unison ring in the turbo along with a few other little things. Also cleaned out the turbo. the unison ring in the turbo was seized to the housing. Last time I was getting low injector control pressure code and underboost code.
Old Nov 1, 2009 | 05:47 PM
69cj's Avatar
69cj
Air flow sensor
EGR system
Exhaust manifold
Just to give people a heads up. The CAC rubber boots are not covered. Checked with 2 dealers here and they ran the parts numbers and said they are under my 100 buck deductible for the engine, not the emissions.
90F250351's Avatar
90F250351
they charged the $100 deductable for that service. the truck has 50k on it
Old Nov 1, 2009 | 05:51 PM
bismic's Avatar
bismic
According to the manual, the turbo is covered at no deductible.
Do you have a warranty manual? You have grounds to recover the $100. You may have to write Ford if the dealership does not want to acknowledge the emissions warranty coverage.
Ford Motor Company
Customer Relationship Center
P.O. Box 6248
Dearborn, MI 48121
1-800-392-3673 (FORD)
(TDD for the hearing impaired:
1-800-232-5952)
www.customersaskford.com
Old Nov 1, 2009 | 06:44 PM
90F250351's Avatar
90F250351
do you think the issues I'm having has anything to do with a bad ICP sensor? Isnt there a way to test? something like unplugging the sensor and seeing if the truck still starts?
Old Nov 2, 2009 | 10:17 AM
90F250351's Avatar
90F250351
anyone know???
Corvette95
Aug 13, 2020 02:11 PM
buildmyown
Sep 24, 2013 07:13 PM
turbo930ss
13
May 17, 2013 12:36 PM
RedDragon777
1997 - 2003 F150
Aug 2, 2012 11:17 PM
Peace2Peep
May 11, 2012 07:46 PM
