Hey y'all I have a 03 F250 4x4 105,000 miles the P0225 code showed up a few months back with erractic idle and jerking while going down the road it seem to straighten out and I would clear the code. Now the truck is doing the same as above at all times and as soon as I clear the the code with in a few miles it reset's I run syn. 5w-40w and changed the fuel filters as soon as this started. I checked out the Tech page really great info!! Sounds like it has to be ICP sensor. Just wanted to check in with the Pro's before I started to dig it out of there. Great forum and thanks in advance.
When my TPS went out in the 350 I would have sworn that it was the ICP but the ICP was only a couple thousand miles old.I had no cel but after some figuring was a dead spot in the pedal that had the same effect as the ICP surging.New pedal for a hundred bucks and problem solved.
