What factory 17 inch rim will fit on my 2002 f250 superduty 4x4 as I have some almost new 17" tires that I got from some one I know and would like to use the tires some day on my superduty or if there are any aftermarket wheels for a decent price? Thanks
Jeff7825 got a factory set of harley wheels that are 17in from an 04 no backspacing required.
Mine are actually 18s. The 05+ wheels will bolt up, but you will have to run spacers so they won't rub.
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
Adam, Farmb0y, has some 05 Lariat wheels on his '99.
Not sure if he had to modify them or not.
They're 20" '06 wheels, thank you very much!!
You will need 2" spacers to make them work, otherwise they'll rub your leaf springs. I tried them without the spacers; it made it look like a railroad truck.
I think the offset difference between the two wheels is right at 1.75", so with the 2" spacers they sit a bit wider, but it sure looks good.
Oops. See what happens when I think? I knew they were larger than 17 but I also knew they were the wheels with a different offset pattern that aren't "supposed" to fit our trucks.
