power window problem
Old Oct 31, 2009 | 10:18 PM
bigford8486's Avatar
bigford8486
Question power window problem
the drivers side power window goes up really slow and sometimes wont go up at all with out help. any and all help would be gladly taken thanx
Old Nov 1, 2009 | 11:42 AM
n5926g's Avatar
n5926g
Im not sure about the specific setup,but sounds like its window regulator assy time.
I replaced one in my daughters Alero a few years back,and it was a breeze really.I was prepared for an all afternoon job.
IF the regulators in our Fords are anything like the cars are,its an assembly of plastic wheels,cables,and a motor.
There is a possibility that its binding at the lower seal,or perhaps "garbage" in the window track itself.
Go to Auto Parts Fast at RockAuto and look up your window regulator assy...once you have found it,click on the info icon,and youll be able to see what it looks like...
Old Nov 2, 2009 | 01:33 PM
1Aauto's Avatar
1Aauto
Former Vendor
Sounds like the window motor's getting tired.
Old Nov 2, 2009 | 06:05 PM
tbear853's Avatar
tbear853
It helps ease their burden to periodically take a can of spray silicone, put the little tube on it, roll the glass down, use a rag to control overspray, and soak the window track.
If it runs out the bottom of the door, it'll wash off.
Old Nov 4, 2009 | 10:29 PM
soundwave's Avatar
soundwave
I just took my 07 to the dealer last friday to get my drivers side window fixed under warrenty. The window went down with no issue, but i'd have to push the button quite a few times to get it to go up. It seemed like a short, because sometimes it would work fine.
The dealer replaced the switch, and it took about an hour to do..not bad. On the paper work it said "replaced driver side window switch..known problem" and the guy at the shop said they've had a few people have the same problem.
teamlx88
Feb 2, 2014 03:34 PM
wickware
Sep 15, 2004 02:33 AM
Realm
1978 - 1996 Big Bronco
17
Jan 15, 2004 11:41 PM
jlag
Dec 9, 2003 07:48 AM
shotgunner426
Oct 3, 2003 04:06 PM
