Blue smoke
Old Oct 30, 2009 | 09:01 PM
Vinford's Avatar
Vinford
Blue smoke
94.5 F-350 4x4.
What are the common causes of blue smoke.
Gets real smokey if you rev it up some.
Old Oct 31, 2009 | 09:38 AM
foxracing0934's Avatar
foxracing0934
That sounds like injector o-rings to me. If the seals are bad then it will allow oil to pass by the injector and leak I to the combustion chamber and when it burns it burns blue. O-rings are fairly common on higher mileage motors and are quite simple to replace, it can be done start to finish in probably 4 hrs, + or - an hour or so depending on if you've done them before.
Old Oct 31, 2009 | 11:03 AM
97-psd's Avatar
97-psd
x2 on the o-rings, it is fairly common,
Old Oct 31, 2009 | 05:31 PM
FARM69's Avatar
FARM69
x3 on o-rings. Unless it's happening during cold starts but clears up in a decent amount of time I wouldn't be worried about it.
If your choking out the entire yard I'd be concerned, but these older diesels do smoke a little on a cold start.
Old Oct 31, 2009 | 06:21 PM
Vinford's Avatar
Vinford
Its smoking enough I wouldnt want to start it in a church parking lot, they would get smoked out.
So its got a embarrasing amount.
Old Oct 31, 2009 | 07:53 PM
c00nhunterjoe's Avatar
c00nhunterjoe
if it is only while revving up on a hot engine and if you put it to the floor in park or neutral and the truck stumbles from 2500-3100 then it is 99.9% guranteed injector o-rings.
here are a few comaprison videos for you as far as cold start smoke goes. my truck has fully functional glow plugs and good solid compression.
this is a 2 day sit in mid 30's- YouTube - cold day truck start
this is a 2 hour sit in mid teen weather- YouTube - 2 hour sit in cold weather
Old Oct 31, 2009 | 08:55 PM
Vinford's Avatar
Vinford
Its worse when the engine is cold.
I let the oil pressure get up them rev it up some and theres a cloud of blue.
Truck seems to stumble while doing it.
Ive got the truck here and thinking about buying it and trying to figure out how much work its going to need.
Old Oct 31, 2009 | 10:13 PM
c00nhunterjoe
you cant judge rough accel on cold oil. the engine has to be up to operating temps. i have yet to see a 7.3 that didnt have some form of white/blue smoke on cold start.
if it still stumbles on a hot engine and has the smoke then you are most likely looking at injector o-rings. you can get a whole set for under 100 bucks and about a day to replace them for the first timer
Old Oct 31, 2009 | 10:54 PM
Vinford's Avatar
Vinford
I replaced them on my last 94 and it didnt stop the smoke thats why I was asking around.
Ill let the truck warm up real good tomorrow and see what it does when I rev it up.
Old Nov 1, 2009 | 01:17 AM
maverick1701's Avatar
maverick1701
you could always buy it and swap in stage 2s....
Old Nov 1, 2009 | 06:32 AM
FARM69's Avatar
FARM69
Thats a pretty good analogy.
opy
Mar 23, 2017 02:19 PM
James Garber
2015 - 2020 F150
Jan 18, 2017 03:46 PM
daniel1997psd
Dec 5, 2016 01:47 PM
powerstrokecowgirl
6.4L Power Stroke Diesel
Jul 2, 2015 05:26 PM
Redonkulous BOB
Dec 21, 2011 08:55 PM
