97 psd trains need help
Old Oct 30, 2009 | 08:41 PM
ford pride's Avatar
ford pride
new trains e4od shift fine and sometimes will skip 3rd go to 4ththenback to 3rd then to 4th but not in lemp mode and O/D not flashing just changed TPS and speed sensor old trains did same thing then went lemp mode and burnt T/C
Old Oct 30, 2009 | 11:00 PM
oldbird1965's Avatar
oldbird1965
Does it only do it when its cold or all the time?
Old Oct 31, 2009 | 11:25 AM
ford pride's Avatar
ford pride
all the time could it be the TPS not set right
Old Oct 31, 2009 | 01:44 PM
Hussler's Avatar
Hussler
Where did you purchase the TPS (part number)? Most if any won't work properly unless it is the original FORD part. Lots of aftermarket and looks the same but they align differently.
Old Oct 31, 2009 | 09:02 PM
ford pride's Avatar
ford pride
napa but the old TPS was the orignal from ford and it does the same thing
Old Oct 31, 2009 | 09:03 PM
ford pride's Avatar
ford pride
how con i tell if it is set right
Old Oct 31, 2009 | 10:16 PM
c00nhunterjoe's Avatar
c00nhunterjoe
is this a "new"trans to your truck or did you get your old one rebuilt?
going to limp mode does not burn up the tc. if the tc got toasted then you had clutch issues.
Old Nov 1, 2009 | 07:18 AM
ford pride's Avatar
ford pride
new from ford
